Question about Roper RAX4233PQ Top Load Washer
Washer will not spin, during rinse & I'm assuming spin cycle
Roper, Whirlpool top load 7 speed, 2 speed washer. History, machine would spin very slowly during spin cycle. I tore the ****** down, cleaned everything, changed oil ~ gears in great shape. Only thing out of the normal, found a gold anodized pin that was between tub unit and upper mounting unit (?) Pin is .20 dia by 2.0 overall length, .30 dia head x .08 long. along complete shaft a ground flat .165 from edge of OD. Pin comes to a point with .08 through hole for a cross pin. Very little wear marks on the OD by the head....... Now I have zero spin. Thoughts?
    Genius:
  • 1,028 Answers
Throw pin in trash..shipping pin..spin problem..if motr runs and unit agitates suspect transmission or clutch on top of transmission
Posted on Nov 27, 2008
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
The washer tub on my Roper washer does not spin during rinse cycle. The motor coupling seems to be OK.
SOUNDS LIKE A LID SWITCH OR A BAD MOTOR OR TRANNY. I WOULD CHECK THE LID SWITCH FIRST
Nov 03, 2009 | Roper RAS8445KQ Top Load Washer
Washer not filling or agitating, during wash & rinse cycles
HI, this will occur if the timer mechanism has become unstable. you will need to replace this defective timer control module asap, if possible.
Jul 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Sep 21, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAX4233PQ Top Load Washer Logo
224 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
