Question about Toshiba D-R400
Program records only without video sporatically in timer mode
I have owned the Toshiba D-R400 DVD recorder for about 6 months now without any issues until recently. I purchased this particular unit because it doesn't use any copyguard when recording. Every once in a while, when I set up the timer to record it ends up recording only the sound and not the video. I noticed once I turn back on the unit, everything checks out ok. Most of the time it will record a program successfully, but recently it seems to be doing this more and more.
A few times I set up the timer to record 2 movies at 2 different times. The first movie recorded fine, but the second program ended up with only sound and no picture.
Last night I set up the timer to record a movie early this morning. During the recording, I turned on the TV to check it and found there was no sound or video on the TV, regardless if I was in the AV1 mode or TV mode. I had to stop the timed recording and change the channel in order for the sound and video to reappear. I never had an issues with the cable box in this regard, only the Toshiba recorder. Any ideas why this might be occuring?
5 Suggested Answers
dvdcdlaser
  • 1285 Answers
SOURCE: Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Posted on May 27, 2009
SOURCE: Toshiba d-r400 recording
I don't see anywhere in the program menu to input a channel number to be recorded, only date and time.
Posted on Jan 25, 2010
  • 11800 Answers
SOURCE: Toshiba Model D-R5SU DVD Recorder Default
The timer and the schedule memory (and its activation) are kept active by the power source of the unit. In your case the source is no longer delivering the stable voltage the memory circuit and the processor needs to keep the data stored and processed - a sign that the source has aged and its components, mainly the filtering capacitors, will have to be replaced by a repair shop. You must take the unit to one, there is nothing else you can do to it.
Posted on Jul 03, 2011
  • 1156 Answers
SOURCE: Toshiba dr7 DVD recorder. Using timer recording
Hi, thanks for posting your Question.. This problem might be can be due to a writing error problem on bad media. What's more, this error is 'non-critical', and can easily be cleared in most cases by the user.
Press 'DISPLAY' button (should be on remote); this should clear it. Also check to make sure the recordable DVD media is 4x - 8x write speed. Recommended media brand: Verbatim DVD-R/RW if you can get it, or Kodak will work.
Discard any discs you previously used in this machine which may have triggered the error.
Or you can try the below step.
Unplug the unit from the wall AC outlet for two hours to reset .. If it doesn't reset, Turn on unit, select Hold channel up and play buttons on front of the unit for 5 seconds..Unit should reinitialize and work better..
Good luck to you..
Posted on Jul 13, 2011
I have a d-r2sc toshiba dvd recorder that will not recognize a dvd-r 4.7 gb version 2.1 disc. I get an error message saying "Check disk. May be damaged or may require cleaning". I have tried...
I've got it!!!!!!!
Although this is an old thread, recently I had an idea about my own Toshiba DVD Recorder. Same problem all over the grid when it comes to this model and hopefully some of you who currently have this problem will find my post and once again be using your unit as I am mine. The problem is so simple you'll flip! This Toshiba DVD Recorder device is exactly what we're all using as DVD burners in our home pcs, just a Toshiba in this one though, I had an LG multi-writer, dula layer, blah blah blah and when I opened up my Toshiba unit, saw how the screws go into the sides, the IDE connector is EXACTLY what we will find in our PC's, the Toshiba jumper pin was set to MASTER and like modern day DVD or CD drives, we no longer need to connect an audio connector to get what else, but audio.
Early today I looked closely at my LG replacement unit, saw that the tray is more shallow than the original Toshiba one. Most of you know why the tray is so deep? Because with this unit one can use the cartridge-style DVD-RAM disc but since a PC's dvd tray is not as deep, I just ripped into the case and used the actual ram disc without it. The Software Version for the Toshiba is ZN10 and the DVD Drive Software WAS 1309. The drive software will change to whatever your newest PC-DVD recorder will be. In my case I had a 2006 LG and the Toshiba was a 2004 but irrelevant anyway. One thing you must remove from a PC type DVD recorder/burner, is the front access door and the surrounding trim since inside the Toshiba home unit, no door or trim attached to the Toshiba's DVD unit but of course you would notice that the silver door opens when the eject mech. is actuated.
For 2 years my Toshiba was malfunctioning, would read older discs I had recorded and finalized, some of the other discs I had recorded some things on but didn't finalize, I was able to do so today. The problem I have heard about these Toshibas is that their laser units are el cheapo but kind of ticked me off because we paid $550 in 2004 for this thing and no hard drive of course. I do have an issue with my clock on this thing and maybe because we had it plugged in for the past 8 years or so. When off, nothing on the display, when turned on the display shows the time and then it blanks out and we can only see the elapsed time, counter etc. Not that it matters but don't think I'd ever buy another Toshiba device anyway now.
Hope this has helped and trust me here, if your unit still powers on and you keep seeing the disc read error etc., you can probably find yourself a brand new dvd recorder for about 30 bucks retail and problem solved. Oh yeah, one interesting note and if I hadn't mentioned this now, some of you would realize it anyway, this unit will now record + and - since it's actually a PC recorder device LOL. Stupid Toshiba made this as only one type and that was -R but for the life of me, can't figure out why it couldn't have been both/all types. Really have to add about what I was reading awhile back too, some were advising that one couldn't use -RW types (rewriteables) but the issue actually stems from the laser and unit's weakness at reading better quality discs. The ones I had copied and finalized as WRITE ONCE (only) were really cheap ones and they have always worked. Prior to doing this unit swap I tried a store bought movie and it wouldn't read it at all, then when I did the hardware change, VOILA!
Jan 08, 2011 | Toshiba Televison & Video
I have no sound through my tv, when watching through the D-r400. This has not been a problem prior. If I watch through my TIVO, sound is good, but when I switch to the DVD recorder, I have picture, but...
have you tried any of the internal audio option within the players on screen menu's perhaps it got switched to a digital output in there somehow instead of the hdmi your needing to use
Dec 19, 2010 | Toshiba D-R400
May 03, 2009 | Toshiba D-R400
Toshiba D-R2su Recording Error
I've got it!!!!!!!
Jan 27, 2008 | Televison & Video
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
Fan doesn't turn off in standby
HAve you checked to see if it is the fan or the actual rom drive that is spinning, I had this problem, email me for any help chickyxr@optusnet.com.au
Nov 08, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Open Questions:
Toshiba D-R400 Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
