Question about Stoves 720EF Electric Double Oven
Cant work oven!
Hi! I recently bought a home and found that I could not work out how to properly operate the double oven. The Oven is a Stoves Panache EF902. I have just rang the manufacturer who said that they can notsupply me with a handbook as the oven is obsolete.
Any idea where I might obtain operating instructions as the blumin thing is beyonf my limited understanding of double ovens!
Cheers and really hope you can help
  • nmdek Nov 29, 2008
    I have just moved in to a new flat. The stove is an Ariston (Manuel for installation has FV271, 242D and A2013 on the cover)
    I can't get it from Automatic to Manuel.- I tried setting the time/r (depressing the "hand" (manuel) button and the "+" and "-" ) buttons but to no avail. - I think that I have to set the clock first and then get it from automatic to manuel.
    If someone can help with:
    1) Setting the time/r , and;
    2) Getting the oven from Automatic to Manuel, I would be most grateful!
    Many thanks,
    Nicole
  • 250 Answers
I have the Stoves 720EF manual stored on the BT Digital Vault which might help. If you want a copy of it, supply an email address and I will give it access.
Also someone else has said that if you speak to Stoves nicely they may be able to send an electronic version of the manual instead of the paper copy.
Posted on Mar 25, 2009
I HAVE BOUGHT A SECOND HAND STOVE ELECTRIC OVEN MODEL NO. 720EF . CAN I GET A OPERATION HAND BOOK
STOVES don't have any and from past experience are reluctant to help. I now have a copy in .pdf format for anyone who wants it. All I need is an email address to send it to you.
Nov 22, 2010 | Stoves 720EF Electric Double Oven
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
A (automatic cooking)remains in the digital reader which means that the electric oven/grill and fan oven won't work. It will not clear from the box.
What happens when you turn the power off to the whole oven, leave it off for a few mins and then reapply? If the automatic is still set it could be the clock is faulty.
Have you tried resetting the clock as per the handbook?
Dec 01, 2009 | Stoves 720EF Electric Double Oven
How does the q900 works
I do not know either but I would be tempted to turn off the gas, but keep the electric to the oven, and use a plastic Knitting needle to find out. It should show on a display somewhere.
Feb 11, 2009 | Stoves Premier 720GRa Gas Double Oven
Stoves genus 900 will not switch on
I have a power supply for one and also a front panel dont know if this helps.
Jan 19, 2009 | Stoves 720EF Electric Double Oven
I cant work out how to switcg my stoves newhomes gl706 grill oven on
this product is made by encodex. No manual could be found online. Check if pilot light is on and you don't smell alot of gas. encodex is a sub company of GFK group. Here is there number, Tel. +49 911 395-0
Dec 28, 2008 | Stoves Premier 720GRa Gas Double Oven
Hi i cant seem to get my grill or oven on can any one help
thanx for the site guys i got the no for the co and they going to get back to me thanks again
Stoves 720ef top oven warms but does not reach high temps. element replaced - no fix. thermostat ok as heating light cycles on and off at around 120 deg C, but reluctant to get hotter.
Have the same problem. Went and bought an oven thermometer from Lakeland and found that when the top oven thermostat was set to 160, the temperature only got to 140. I did clean the sensor inside the oven using a cleaner from Lakeland which did improve matters but it is still running cooler that it should. ( It takes at least 20 to 30 mins to warm up)
May 01, 2008 | Stoves 720EF Electric Double Oven
Stoves 720 / 900 GRa GR DO gas electric dual fuel oven
Our oven had the same fault.
It turns out that the air intake was blocked.
The air intake is at the front, just below the bottom oven door. Some liberal sucking with a hoover sorted the problem instantly.
Apr 06, 2008 | Stoves Premier 720GRa Gas Double Oven
Oven light
how to change the light bulb in the oven of the stoves panache 6oosidlm
Sep 02, 2007 | Ovens
Stoves 720EF Electric Double Oven Logo
311 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
