Question about Canon Pixma iP2600 Photo InkJet Printer
Printer not working.
I cannot get the ink to click into position, plus the two lights keep flashing. I get an error message, but no solution.
I get a paper jam light but no paper is jam my printer is new whats up!!!
Posted on Dec 04, 2008
Error message E-1-6 lights keep flashing
Hi Stacey,
Go To Below official Canon Printer Video For Your problem and Solve your problem
Still having Problem Then follow Us For Canon Printer Support
Feb 24, 2014 | Canon MP270 All-In-One InkJet Printer
Tow red signal
  1. Make sure the printer is turned on, then open the printer cover.
  2. Do one of the following:
    • If the red error light is on, press the Maintenance button.
    • If the red error light is flashing, press the Maintenance button. You see Ink Cartridge Replacement, highlighted in the Advanced Settings menu. Press OK.
  3. You see a message on the LCD screen telling you that ink cartridge replacement will begin. Press OK to continue. The print head moves to the replacement position.
  4. Open the cartridge cover.
  5. Press in the tab on the back of the cartridge and lift the cartridge out of the printer.
  6. Lower the cartridge back into the holder, with the green circuit board facing the front. Then gently push the cartridge down until it clicks into place.
  7. Close the ink cartridge cover.
  8. Press OK and close the printer cover.
    The printer begins charging the ink delivery system.
  9. When you see a message that charging is complete (after about a minute), press OK.
Dec 06, 2010 | Epson STYLUS R230 InkJet Photo Printer
I keep getting a cartridge 50C cartridge error on my printer. What can I do to fix it? I can't print just anything. The test printer works but I can't print anything else.
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 07, 2010 | Dell A960 All-In-One InkJet Printer
The orange light keeps flashing
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 22, 2010 | Canon I990 InkJet Photo Printer
Error 50c, recieving this error when trying to print or make a copy
Hi there Error 50c
It works for the 940 it may work for the 960 too.
color cartridge.
Oct 07, 2009 | Dell A960 All-In-One InkJet Printer
After installing new ink cartrages the two red lights keep flashing and I can't check the cartrages to see if they are seated properly
Do you have a message on your screen ??? Try printing a document or opening the print manager and see the error message - that looks like a maintenance error when your pads need to be serviced after a set number of prints.
Press the button to set the carriage in ink change position - while your carriage is in the ink change position UNPLUG YOUR PRINTER.
ONce printer unplugged from electrical wall socket - remove all carts, and then place them back one by one making sure you use the right color for the right slot - make sure they snap in securely, close the latch.
Now plug in your printer and wait for the initialization process and see if this works....
If you still get the blinking lights, you will need to locate the error message - your printer pad counter has reached its maximum and it needs to be serviced and reset.
There are reset software out there, but you need to change the pads or divert the tube to a tank outside your printer.
Sep 26, 2009 | Epson Stylus C86 InkJet Printer
CANON MP210 ERROR E15 - INK NEW PRINTER, NEW INK
Go to this link. In the search window in the center of the screen, type "error e 1 5" and click on the Search button. Select the appropriate error message, then select the answer that says "reseat ink cartridge". You may not have locked the cartridges into place by lifting up until they click.
Oct 24, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
The red light keeps on flashing
HI-
Turrn off the printer then unplug it for a few minutes. replug it then try pressing the maintenance button once or press and release it, if it doesnt move to position where you can change it press on it again. If this doesn't help. Go to start on your computer, go to setting then control panel, click on printers and faxes( then right click on the printer icon and left click on printing preferences then) look for utility or maintnance tab then there should be an option to replace ink cartridge.
Keep me posted
Sep 15, 2008 | Epson Stylus C43SX InkJet Printer
Ink light flashing
whip the cartridge circuits with the tissue paper, if the problem occurs the same thing than this is the service station error mean s the software has to be installed again
Mar 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Ink tank lamps - the magenta horror
Call Canon, this is a chip error on the ink tank itself, they replaced mine.
Jan 27, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon Pixma iP2600 Photo InkJet Printer Logo
174 people viewed this question
old marine
old marine
