Question about Microsoft Wireless Laser Desktop 4000 Keyboard/Mouse
How do I get a "CAPS LOCK" indicator or light to appear?
The keyboard functions OK (I guess) but I can never determine if my CAPS LOCK is "on or off" until i type. I received no manual in the box when purchased so i have no clue. Also, what is the toggle switch to the left of the Tab Key (+ & -) and what is the "F" Lock key?
Issue 1)The cap lock light is on your remote unit. (There 3 indicators "A" - "1" & "F") When your cap lock is pushed the "A" light will light up - Number lock same & F lock likewise.
Issue 2) The slider left of your tab is your zoom control. Slide it to the top for larger, down for smaller.
Issue 3) "F Lock" - You will notice that all of your keys above the number line have 2 functions listed on them, ie F1-Help F2 -Undo etc... When you push the "FLock" key, the light on the transmitter will light and your keys function as F1, F2, F3 etc. Push the button again, the light gors off and now the keys function as Help, Undo, Redo etc. Hope this answers your questions.
Joelunchbucket
Posted on Nov 28, 2008
    Problem Solver:
  • 7 Answers
Most keyboards now a days usually tell you on screen whether or not the caps lock is on but its possiblbe that when you press the key yowards the left or right hand side a light goes on or possibly in the top center if this is not the case then you may have a faulty keyboard.
Posted on Nov 27, 2008
Keyboard CAPS LOCK light working in reverse
whoever opened up your keyboard messed up with the light cables, open cable and see if you can put back cables in correct connections.
Mar 22, 2014 | Acer KB.T.3007.006 Aspire Keyboard us P/N:...
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
On the computer keyboard by nextech is there suppose to be keyboard lights and if so how are they turned on
Hi
The usual lights for a keyoard are the 3 above the number pad. they will be labelled to correspond with the following keys:
- CAPS Lock
- NUMBER Lock
- SCROLL Lock
When they are pressed once the light will go on, meaning that function key is active. So if the CAPS Lock key was pressed and the light is on, then any letter key (A to Z) you press appear as a capital in documents. Press CAPS Lock again and the light goes out and the letter will type lower case.
The NUMBER LOCK is for the keypad to the right (not the number across the top and above the letters). This function ensures the numbers will appear instead of their alternate function, such cursor and Page UP/down, Home, and End.
SCROLL Lock is not used much, but it can be used in Excel to hold the current selection. For example, you want scroll about the sheet using the cursor keys, but want to keep the current cell selected. So with SROLL lock active, when you use the cursor key's, the sheet will move in the direction you want while leaving the selected cell selected. Try it and you'll see what I mean.
I hope this helps.
Mar 01, 2011 | Lenovo Keyboard
Where on keyboard is indicator to show caps lock on or off?
it is not on the keyboard, but on a LED light on the panel, on the hinge cover.
Oct 26, 2009 | Dell 0Y3740 Keyboard
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Cap Lock on or off
Feb 11, 2009 | Logitech Cordless Desktop EX110
Meaning of indicator lights on wireless receiver
I concur 2/3's with yooperbud.
1 = System is connected and working
A = Cap locks On= Cap lock is on. Off = Cap lock is off.
F = Function Key usage. On = I'm going to use the alternative fuctions of the F keys as programmed in the Keyboard settings. Off = Your using the standard features of the F keys.
Dec 31, 2008 | Microsoft Wireless Optical Mouse USB...
Microsoft Wireless Laser Desktop 4000 Keyboard/Mouse Logo
501 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
