Question about Toshiba Satellite A100-S8111TD Notebook
How does the lcd screen remove to check connections
Is the screen easy to remove?
    Novelist:
  • 150 Answers
Fairly easy for someone who is handy and has a little patience... Usually only takes 6 - 10 screws to remove the screen; but doing the work is at your own risk.
Posted on Nov 27, 2008
Screen blank
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Feb 09, 2011 | Dell Inspiron 1525 Notebook
My lcd does not display anything when turned on
Feb 04, 2011 | Dell Latitude D810 Notebook
SCREEN FOR MY NOTEBOOK IS NOT WORKING BUT THE PROCESSOR IS RUNNING
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it. Usually you can find cheaper replacements on Ebay.
Jan 15, 2011 | Fujitsu Siemens LifeBook S6120 Notebook
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
Jan 06, 2011 | Computers & Internet
No display on monitor
If the laptop acts as it would start and there's just no image, look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
Jan 05, 2011 | HP Pavilion dv6000z Notebook
Hi, my hp dv2000 screen is blank when I turn it on. It hums and lights up like it's supposed to, but the screen is completely blank! What do I do?
Nov 30, 2010 | HP Pavilion dv2000t Notebook
Blank computer screen
Nov 09, 2010 | Toshiba Satellite Pro L300 Notebook
Blank screen
Oct 18, 2009 | Acer Aspire 3000 Notebook
TFT Screen Loose Connection?
Hello!
These models sometimes have a problem with flickering screens, screens going black, etc. This is caused by the cable running from your LCD lid area to your motherboard.
To gain access to this cable, flip your laptop upside-down, but make sure the back is facing you (vents and such). There are 4 screws along this side, you only need to take out the middle two.
Once that is done, flip your laptop upright again, open the lid and pry up the power bar. The cable you seek is running on the right side, should be wrapped in gray-colored tape.
Adjust this cable so that it cannot move and is not being pinched, and you should be set.
If that didn't work, and since your LCD is no longer lighting up at all, I'm almost leaning towards your problem being your inverter board. Very easy to swap out, and cheap at around $20 at darntoothysam.com.
The LCD inverter board is located at the bottom front part of the LCD lid. Just take off the front frame of your lid by removing the power bar (as instructed above) and then removing the screws under the rubber bumpers on the LCD frame. Then it's just a matter of carefully peeling the glue holding the frame down at the bottom.
Your inverter board is the long green-colored board you should see with the front frame removed. This board will have two connections plugged into it. Quite the easy swap, yes?
Nov 06, 2007 | E-Machines M2350 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
19 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
