Lcd, display with red instead of black
Hi please can you help dianosing the problem, pc will display normal desktop with proper colour but when playing a film and needs black in background its using red which leaves the picture un-watchable. up-dated driver for graphics card!
  • 153 Answers
Check the Video cable and try moving the it around and see if the color will come back normal. This kind of problem can be cause by faulty cables.
Posted on Nov 27, 2008
~Hello! My monitor dispays picture, but the picture isnt like it should be. Instead of normal colours it displays gray stripes, red is shown as yellow, windows 7 startup icon is in black box ect. When...
Hey, have you bene able to try another monitor and see if its the same thing?
Check andmake sure that all of your cables are tight and secure. If they are then you probably have a bad video card. they are fairly easy to replace:
Jul 15, 2011 | BenQ FP737S-D 17" LCD Monitor
Hi. I have hp 6735s laptop and when I move him screen suddenly go black or in rare case white and I need to hold power button to shut down and when I turn him on everything is normal until I move him again...
When you say you move him, do you mean lifting the unit and moving to another location or just moving the lid (changing angle of the lid/lcd)?
If changing the angle of the display gives you black/white screen, you may be having problem with the LCD cable, it might be loose or defective. But if moving the unit to another location gives you the black/white screen, one component of the unit might be loose. Either you need to properly reinsert the memory of the harddrive. If these simple steps will not resolve the issue then you might need to check the whole motherboard including the connection to the LCD.
Hope this helps.
May 19, 2011 | HP Compaq 6735s Notebook
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
Elonex webbook displays anything black as red
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 08, 2009 | Computers & Internet
POWER SUPPLY 24 pin slim line colour code ,hp compaq dc 7100
normal white wire....?
white with red....?
brown....?
Mar 31, 2009 | HP Compaq dc7100 PC Desktop
Hi. i am using Dell inspiron 6400. i have been using it for more than a year now. since yesterday i am experiencing a new kind of problem. my display was working fine untill yesterday. i have windows XP as...
Sounds like you have a failing backlight. The flourescent tube at the bottom of the LCD that make the screen bright enough to see will change to a reddish tinge as it goes bad. Eventually the tube will not generate light at all and the screen will go black, but you can still see the image faintly if you use a flashlight at an angle to the LCD surface. You might also hear a faint buzzing sound, just like when an overhead flourescent goes bad.
Replacing the backlight is a tedious and difficult job. First the LCD panel has to be removed, and then it must be disassembled to get to the backlight. The tubes can be purchased on eBay but they are leaded glass and very thin, so they tend to break easily. There are two contact tips must be desoldered and then the two new ones soldered before the LCD panel can be reassembled and then put back into the upper half of laptop.
For a beginner, it is much easier to replace the entire panel with a new or known good used one. Best bet is to check your warranty first, otherwise a full LCD panel will cost at least $75 plus the labor to install.
As for the TV out, the preferred method is to hook an external by VGA cable to test the video card. You should get full picture with proper colors since the problem is in the laptop's display itself. The TV out jack requires drivers and a functioning XP to display.
Dec 30, 2008 | Dell Inspiron 6400 Notebook
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Hitachi 32LD6600 - When the TV has been on for abot 30 minutes the colours start to go blue/red and the picture is distorted,noting I do gets the picture to display as normal.
Hi i have this tv and last night the screen went black i can hear sound ok but no picture just a black screen, Also i can see dark
outlines /shadows of whats on the tv, can you tell me please what has caused this
Mar 05, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Computers & Internet Logo
229 people viewed this question
David Payne
David Payne
