Question about Brother MFC-7820N Laser Printer
Can you printer a double sided page? If yes how? The manual does not explain and can not find any info on the machine it self kind regard Valeen Jackson
  • Jordan Mkt Mar 24, 2017
    Get brother helpline at brother printer tech support phone number 1877-778-8@9@6@9 for USA|Canada. Use our brother printers technical support phone number for instant help. For More Visit Us Here:https://goo.gl/73VrU3
The 7820N prints double-sided manually using the drivers. From Windows, select File / Print. On the pop-up window, click on Preferences, select the Advanced tab, click on the A/B pages icon, and select Manual Duplex. "OK" your way out. When you print, you'll first confirm to print one side of all pages. Then follow the instructions that appear.
Posted on Jan 31, 2007
Is it possible to copy double sided pages using brother mfc 7430?
actually, this machine is not design for bouble side printing, but you can manually do that if you want to, just need to open the front manual feed cover to do it.
Feb 09, 2011 | Brother MFC-7340 All-In-One Laser Printer
Setup von MFC stürzt beim starten gleich
  • Unplug the printer from AC outlet.
  • 2 Make sure the printer is not connected to your PC. Disconnect it, if it is connected.
  • 3 Go to the link to download MFC-7820N driver. Select your operating system and language and download the driver.
  • 4 Double click the downloaded file to extract it.
  • 5 Open the folder extracted in Step 3 and go to the "Setup" folder.
  • 6 Double click the "Setup.exe" file while holding down the Shift key on the keyboard. This will start the installation. Follow the instructions on screen to complete the installation.
  • 7 Connect the printer to your IBM laptop via USB or parallel cable that came with the printer. The MFC-7820N comes with both the USB and parallel interfaces. You can use either one to connect to the laptop.
  • Dec 06, 2010 | Brother MFC-7820N Laser Printer
    MFC-7820N Laser Printer: I amm trying to print off a apy slip but they keep...
    When you are you using any type of differen tpaper on this machine you should use the manual feed. Manual feed is located right above the tray.
    May 16, 2010 | Brother MFC-7820N Laser Printer
    Toner on my mfc-7820n brother printer is full, but it won't print dark. VERY light only. any ideas?
    Hello, I can solve this problem and get your machine back in working order. My fee is $50 for labor and part plus shipping. Let me know if you are inst rested.
    Jan 05, 2010 | Brother MFC-7820N All-In-One Laser Printer
    Bad Scan Quality Using Brother MFC-7820N Document Feeder
    Look to the left side of the flatbed glass for a thin strip of glass by itself. When you scan from the glass, the document stays put and the sensor moves across the document. When you scan from the feeder, the sensor stays in that glass strip and the document moves across the sensor. See what I mean? I would check the small feeder glass for dirt or scratches from staples or other flotsam. Also not a bad idea to blow out the feeder path with some compressed air to ensure the documents is handled smoothly. Hope this helps!
    Sep 18, 2009 | Brother MFC-7820N Laser Printer
    Brother MFC 7820N
    how do i program one touch dialing on my brother MFC 7820N fax machine
    Sep 09, 2008 | Brother MFC-7820N Laser Printer
    Scanning multiple pages
    Use paper port software which is part of brother software suite but under different menu (check out under start - programs - paperport
    Feb 05, 2008 | Brother MFC-7820N Laser Printer
    Brother MFC-7820N Laser Printer Logo
    394 people viewed this question
    James Cagle
    James Cagle
    ctnozil
    Victorman
    Victorman
