Question about IBM ThinkPad R51 Notebook
My IBM r51 is not able to start whenever I try to start the machine a strange beep sound comes out of somewhere from the processor the battery indicator flashes for a secong and is dead after the beep sound I am trying to charge the batteries since a long time but while I do so the charging indicator is okhay but i fear that it is not actually charging.
  • controlsigna Nov 27, 2008
    Hellow Maite,
    I tried to clean the start up button but no avail,The beep sound I hear is too short and of very low intensity but I am sure it is not from the speakers.The battery is not charging it is totally down and when I remove the battery and try to start the machine from direct supply problem persists I would be really grateful if you give me a solution ....!
    Junaid.
Hi junaid,
just got the same problem now(17/06/09)..some people are suspecting some type of IC problem..could you please tell me if you could solve your problem please.My email is sjuddoo@intnet.mu.
Thanks,
Suraj
Posted on Jun 17, 2009
    Scholar:
  • 83 Answers
Good day!
If you hear a long beepsound it is the memory problem. It may be dirty. You remove it and clean. Use eraser to clean the gold pins. If you hear a continues sound it is a mother board problem. Try to check the connections because it might be the processor doesnt work properly. It may need cleaning. Try to check also your power button. Press it properly. Sometimes it has dirt inside the button thats why no connection to your power button.
Try to post any result so that I can give you more trouble shooting tips.
Posted on Nov 27, 2008
Window comes up off center, How to put window into center. IBM R51
Sometimes this is caused by a loose video cable. Try taking off the keyboard and gently pull up & then reseat the video cable.
Plz be sure to do this with the machine unplugged AND battery removed.
Good luck
Feb 22, 2013 | IBM ThinkPad R51 Notebook
KEYBOARD NOT FUNCTIONING AND CONTINOUSLY BEEPING SOUNDS ON IBM THINKPAD R51 LAPTOP
Could be the keyboard has shorted out, maybe something was spilled on it? You can either get a cheap replacement keyboard from ebay (be sure to match the make/model & size) or you can just plug a usb keyboard in & use that. Once into windows go to device manager (right click My Computer on Desktop & click Properties, Hardware) & disable the IBM onboard keyboard.
Feb 22, 2013 | IBM ThinkPad R51 1830 (1830AHU) PC...
Thinkpad R51 will not boot
Try remove ALL media DVD.CD,USB,etc. Shut down, unplug, remove battery, plug in, reboot. Do you get anything on the monitor? Can you access the restore/recovery software? Open the Memory bay and reseat the Memory, open the HDD bay reseat the HDD, Reboot. If no change remove HDD, test, replace if necessary. Have you changed the CMOS battery?,
Jan 18, 2013 | IBM ThinkPad R51 Notebook
I have an R51. Sometimes when it is closed it will go into sleep mode and will not wake up after reopened. Also the Access IBM button does not seem to be working.
it maybe caused the system is too heat or the battery is not charge well (your battery is not good)
if the system is too heat you can buy some thermal paste, put it on your processor
if it cause your battery consider to replace it
Jan 14, 2011 | IBM ThinkPad R51 Notebook
4 beeps are coming in R51 IBM notebook we remove memory module but same issue.
Just Remove the Battery and connect the Power Cable.
Try to switch ON the laptop. Please confirm if its working fine now.
Please post your feedback and Vote if the problem resolved as per your satisfaction>
Sep 24, 2010 | IBM ThinkPad R51 Notebook
My IBM Thinkpad R51 no display at all
sounds like its not getting past bios due to .. i would say dirty ram cards take the ram cards out clean there points put them back in and try again
Jul 06, 2010 | IBM ThinkPad R51 Notebook
IBM Thinkpad 1829 DNC R51 - Audio Problems
try uninstall driver if you can find it and reinstall driver.
Dec 13, 2009 | IBM ThinkPad R51 Notebook
IBM R51 and is having a problem at startup
try removing all the memory modules on the system, usually you'll get beeps. if you do get a beep try one memory module at a time see if you get something on the screen, observe also the lights on the system see if they would stay on or blink or flash. its rare that a virus would attack the BIOS, more-likely a bad motherboard or harddrive can be prevent the computer from starting up. hit me back on the results. thanks!
Jan 08, 2009 | IBM ThinkPad R51 Notebook
IBM R51 Laptop cannot be turned on anymore
does your hard drive have a "caddy" or "drive sled" installed? Mine did the same until I bought one.
Dec 19, 2008 | IBM ThinkPad R51 Notebook
Startup Problem
The power socket could be loosing cause this kind problem, must re-solder the socket on PCB of motherboard by component level repair tech.
Nov 27, 2008 | IBM ThinkPad R51 Notebook
IBM ThinkPad R51 Notebook Logo
229 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
