Question about Sony Cyber-Shot DSC-P32 Digital Camera
The SMART ZOOM is not working - doesnt either come up in SET UP menu?
I have a problem with the smart zoom it doesnt work when i press it at all. i've read the instructions manual and thought that maybe it could be turned off in the set up menu. i checked by looking on this set up menu but the SMART ZOOM isnt there in the second row = it says: moving image ...........and then, date and time. red eye reduction af illuminator how can i fix this problem? many thanks
  • JoHake Mar 07, 2008
    I have exactly the same problem. When I am taking pictures in camera mode, it won't zoom.When I switch it to edit mode it will zoom. It can't be the zoom motor.
    I fixed my problem myself. Simply read the top of the camera where it says TO USE SET IMAGE SIZE TO LESS THAN 2.8M
    Then go to the very bottom button on your camera (there are three) and press it and reset your image size.Then your zoom will work.
    Problem solved.
Set the camera to take a picture push menu then the button with the trash can and alter the picture size to anything less than 2.8 metres this will work.
Posted on Apr 24, 2008
I fixed my problem myself. Simply read the top of the camerathe SMART ZOOM is not working - doesnt either come - 1.gif where it says TO USE SMART ZOOM SET IMAGE SIZE TO LESS THAN 2.8M
Problem solved.
Posted on Mar 07, 2008
  • 89 Answers
Check whether the DC power supply is reching the zoom motor. If the supply is ok, the zoom motor may need replacement.
Posted on Jan 13, 2007
SOURCE:
Picture too wide on tv
Sounds like you have the "Wide" mode set to Zoom or wide zoom. Also if you are on Comcast cable the cable box has a setting of Zoom and full. Set your TV's zoom setting to "Full" and the cable box to Full. I don't have an LG so you'll have to find these settings yourself..
Feb 25, 2015 | LG 47LM6700 47" Class FuHD 1080p LED LCD...
Philips Magnavox 27MS343S 27" TV picture stretched or zoomed !
Take of the back and there is buttons inside, try turning them.
Nov 25, 2013 | Philips Magnavox 27MS343S 27" TV
How do I disable the PTP mode in my Samsung ST150F smart Came
TO CHANGE THE PTP MODE OFF IN SAMSUNG ST150
1) Turn the camera off
2) Hold the zoom out (-), flash button( PHOTO TAKING) and the Menu button.
3) While holding, turn the camera on.
4) When the camera turns on, it will show a text screen
5) You can let go of the zoom out and the Menu button
6) Press the Menu button
7) Press left. This will turn PTP Mode off
8) Turn the camera off and on, and you're good to go
Aug 21, 2013 | Samsung ST150F Smart Digital Camera Red
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Can't reuse the smart card
try formatting the card using the camera menu... looks like a tomahawk
Apr 03, 2009 | Olympus Camedia C-460 Zoom del Sol Digital...
Olympus c-300 zoom digital camera
The max i've seen verifiably used was 128MB. I have heard reports of 256MB used but could not verify. I currently use 128MB without issue.
Jun 01, 2008 | Olympus C-3000 Zoom Digital Camera
Stuck in manual mode
Check that the wide angle pull out filter is pushed in proberly until it clicks in place also in custom menu check that M ZOOM is set to OFF. (hold zoom and - buttons together for a couple of seconds to enter and exit custom menu)
Oct 06, 2007 | Nikon Speedlight SB-600 TTL Flash
Telephoto images
The D-630 has a 3x optical zoom and a 4x seamless digital zoom. In order to use the digital zoom, press the OK/MENU button on the back of the camera. Press the right arrow key to access the Mode Menu. The first setting under the CAMERA tab is DIGITAL ZOOM. Press the right arrow key to highlight this setting and then press again to select ON. Press the OK/MENU button to set the DIGITAL ZOOM to remain ON. When you press the zoom button with the T on it, a zoom indicator will display on the right side of the LCD. The W represents a wider area of view as you zoom out, and the T represents telephoto as you zoom closer to the subject. When the zoom indicator is in the red zone, you are using the digital portion of the zoom. images taken in the digital zoom will appear “noisy” or “grainy” which is normal when using the DIGITAL ZOOM.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Sony Cyber-Shot DSC-P32 Digital Camera Logo
218 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
