Question about Electrolux Kitchen Ranges
Oven just doesn't work, all other elements, lights timer etc are functional but oven does not heat up no error messages are showing
  • jones1957 Nov 27, 2008
    the model number is CGHES387CB1 and it is an electric range thanks
  • jones1957 Nov 28, 2008
    thanks alot for your help, if it is the control and not the element, what is the part called and where is it located on the stove and can we replace it ourselves instead of calling a service tech
    Sergeant:
    Champion:
  • 338 Answers
What is you model number? if the is a newer range that is electric youcan have a slew of problems if this is gas your ignitor could be bad
Posted on Nov 27, 2008
  • Robert Artiaco Nov 28, 2008
    ok. if you have an electrical meter then there is one test you can do to figure out the problem. slide the unit out. un plug it and take the panel off the back. at the bottom of the unit you should be able to see the bake element. it should have a yellow wire going to it.plug the unit in and turn the bake on. touch both meter leads to the terminalsif your meter is reading 240v then you have a bad element. if you read zero do not touch it because electric is going to it. unplug the unit and replace the control.
    the control is called a few different things it depends on the mfg. the choices are EOC, PCB, Electronic Control, Control Module, Clock/Timer. It should be located behind / conected to the clock.
Have error message on my ne fiigidaire gallery gas range...error Sd...oven will not work and timer etc will not function properly
Some stoves have an override on the oven side... oven pilot light must be lit or it will go to safe mode. if it is an auto light then check the fuse usually located up by the top left side on bk of stove.
Jan 02, 2015 | Frigidaire Gallery 30" Self-Cleaning...
New (graded) smeg scp399x-8 no heat on any of the functions
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Apr 07, 2013 | Smeg Ovens
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
Jan 14, 2011 | Smeg Ovens
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
My candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Mar 28, 2010 | Ovens
I used the self cleaning function and now the over wont work. The lights work, but no heat is produced. I get no error messages, any ideas?
might want to check if element has continuity with light-wire-battery technique or VOM (volt ohm meter)...unplugged and element out... then while element is out can plug back in and use VOM to check element receptacle for 220v AC (to see if power coming to element (good to check also since continuity check can be fooled by a break in the nichrome wire within the element where the ends of the break only retract to make a gap when main current is applied)
........If no voltage at recepticle then between their and control switch/temperature selector.
...the full blast current and heat of self cleaning, could have completed the ready to fail point/switch/etc
Aug 09, 2009 | Whirlpool RBS305PR Electric Single Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
SMEG Oven won't heat up
This is late response but this fault is your fan element. You have two of them, if heating slower than usual, it is only one that has failed. When replacing one, it is recommended the other one be replaced. Tripping the circuit breaker is the symptom. These elements 2100 Watt each are anywhere between $70 to $110.
Service Tech.
Dec 10, 2007 | Ovens
Kitchen Ranges Logo
323 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
