Question about Acer Aspire 5100 Notebook
Pqservice hiya i installed ubuntu then uninstalled it and screwed my system up i managed to get it up and running again with the help off a friend however now when i go into system restore or disc defrag pqservice doesent show before the muck up system restore looked like this pqservice disc C disc D and defragmenter looked like this defragment pqservice disc C disc D now in system restore and defragmenter the pqservice is missing i have an acer m5100 running vista home premium the pqservice is showing is disc management and the pc boots up ok its just the pqservice not showing thats annoying me any help would be greatly apprieciated thanx allan akierszten@hotmail.com my pc is an ACER ASPIRE M5100 (DESKTOP) sorry i put it here but it can't find it below
Uninstalling ubuntu linux 12.04
Boot your computer with the dvd of the OS your want to install and just format the harddrive where the ubuntu is installed.
Mar 03, 2014 | Computers & Internet
Tip
Mount CD DVD images - Ubuntu
1) Are there any programs for Ubuntu
(type: DAEMON Tools, Alcohol or Virtual Disk in Windows)
that will allow me to easily handle my: ISO, IMG, BIN, MDF,NRG , Image files?
2) I want easy to install such a program and immediately using it?
3) Gmount-iso and Furius ISO Mount provide everything we need.
We'll add it to Ubuntu in the following way:
(1.A)Gmount-iso:
1) System> Administration> Synaptic Package Manager
When you open it, you do Reload, Search and install:
gmountiso
2) Run Gmount-iso
Applications-> System Tools> Gmount-iso
(1.B) Furius ISO Mount:
furiusisomount
2) Run Furius ISO Mount
Applications-> System Tools> Furius ISO Mount
(1.C)You can start using your image files in a simple manner.
on Jan 13, 2010 | Computers & Internet
Uninstall os linux ubuntu 13.10 from my laptop
Are you dual booting? Windows and Ubuntu? What version of Windows? You maybe able to reclaim the space by using the Disk Management (right click "My Computer" select Manage then select Disk Management). In there you will see NTFS for your Windows partitions, and something like Unknown for the linux ones, you can then delete the linux partition and possibly extend your NTFS partition to use the free space (depending on version of windows).
If this is a standalone Ubuntu install, you should be able to just use the installer disk for another OS and boot it to reformat the drive.
good luck!
Jan 10, 2014 | Computers & Internet
Uninstall
all the 'programs' installed on your Ubuntu PC are available for uninstall in Ubuntu Software Center.
Jul 11, 2013 | Computers & Internet
How to get su capability, just loaded ubuntu 10.10 want to remove avast application can't get permission to do so.
Start the package manager, search for the Avast program and uncheck the box to uninstall it.
If you need to run a root terminal the run the terminal, enter your password and type sudo -i at the command line>
Regards.
Dec 15, 2010 | Canonical Ltd. Ubuntu
I am trying to get the software or drivers I need to run my Quick web cam. When I changed over to my Linux Ubuntu 10.04 updated again the free software wasn't offered again that I was using the other day....
1st You download Webcam Driver.
software or drivers
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Aug 08, 2010 | Logitech QuickCam Pro 9000 Web Cam
I keep getting a popup telling me my acidbase package or dbconfig-common. or /usr/share/doc/acidbase. needs to be fixed?? I am new to Ubuntu and I don't have a clue what this means. I was just using the...
i would go to Ubuntu software center uninstall it and use Ubuntu tweak to clean any renaming software then reinstall with all the add-ons if you already done this still uninstall and use the synaptic packge manager to install my real advise is to remove it anyway you dont need it. its a security engine, the application provides alerts from a Snort ids system
May 11, 2010 | Canonical Ltd. Ubuntu
Installing web cam on ubuntu system
installing a logitech web cam on ubuntu linux based system
Apr 24, 2010 | Logitech Webcam
Linux
you might have to reinstall your webcam software
Dec 20, 2007 | Philips J44414
D2d recovery
Send me an e-mail and I will send you the fix! If you can't downloadload it from the below link. I had the same problem. The mbr was replaced, you have to add RTMBR.BIN to the MBR and it will work again. As long as you can get on your desktop and run this bat file you will repair the D2D again. Took me an hour to learn what was wrong, It works 100% though.
I have the Aspire 5610Z with the 2GB 533 mhz memory Stock.
Link #1
http://rapidshare.com/files/64293596/Acer_MBR_F10_Repair.zip.html
Link #2
http://www.sendspace.com/file/ngd4ql
matrix@gainbroadband.com
Oct 16, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5100 Notebook Logo
413 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
