Question about Lands Phones
I have NEC DSX-160 I put Line-in 8COIU card & the card is work fine for incoming & outgoing calls. My Question is when the first line be come busy no one can use the others line-in service ,how i can make rule or setup priority for the 8 line-in card so when the first line use be some usre we still can use the 2th line for outgoing calls.(need automatically TRANSFER when the line be busy).
  • 47 Answers
SOURCE: NEC phone system - Forwarding incoming call gets busy signal
please call the engineer from which you have purchased the EPBAX system to congiure the same. It happens if something is wrong in line card at the exchange or the extentions are not configured properly with the Key Telephone System.
Posted on Apr 18, 2008
cnavarro
  • 2460 Answers
SOURCE: Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
Posted on Sep 12, 2008
cnavarro
  • 2460 Answers
SOURCE: i am trying to pass
Wow! Was there a test? I went to the seminar and bought a system and programmed it. If you have the maintenance console and no system, I can probably put mine online so you can practice on it. It's an 80 without voice mail with a trunk and station card.
Your first assignment would be to set up the software for internet access to my system :-)
Carl
Posted on Dec 09, 2008
  • 16 Answers
SOURCE: need to program extension to ring on incoming calls
Professional Level 1 programming to make a phone ring on incoming calls:  1. On the phone you want to change ringing, press <FNC> - 4 and the screen will show the port number and the station number. If it doesnt have a display, borrow one and plug it into the cord that is attached to the wall, then do this. The port number is needed since all station programming is port based.
2. From ext. 10 or 11 (or whatever the extension numbers are for ports 01 and 02 are), with the phone idle press ,<FNC>, <HOLD>, #,0,*. The screen should show "PROGRAM MODE".
3. Press Line Key 4, which is the 4th button across the top. Dial "15", screen should show "01 / 15: 12345678" if you're in the right place. In this mode, the * key moves the cursor right, and the # key moves the cursor left. The first two digits are the port you're programming, the next field is the program code, "15"in our case, which is Daytime Ringing, and the last field is the data setting for this port.
4. Move the cursor to the left so you can change the port field to the port number you found in step 1. After changing the port number, move the cursor back to the right to the data field, and press the digits corresponding the the line number you want to ring, e.g. for line 1 press "1", for line 4 press "4". Each digit pressed in this field is a toggle, so if you press "1" when the digit "1" is already displayed, you will turn off ringing.
5. Verify that the display settings are correct. For example, if you want port 04 to ring in day mode on lines 3, 4 and 5, the display should show "04 / 15:   345    ". If all is correct press <TRF>, and note that the screen advances to the next port automatically.
6. You can change Night Mode ringing by setting the program code field to "16" instead of "15", then the same procedures apply.
7. When all changes are completed, press <SPKR> to exit program mode (or lift handset and hang up).
Posted on Jan 01, 2009
  • 13433 Answers
SOURCE: nec dsx manual
Hey,
documents available at
http://www.necdsx.com/docs/documents.htm
Thanks,
Ekse
Posted on Mar 04, 2009
Outgoing calls not working while i am getting incoming calls on my phone..
phones only work one way
if the line is engaged no other calls can be made
this works on a single line premise but if you have a multi line installation ( business ), then get a service technician in to diagnose the fault
Oct 26, 2015 | Lands Phones
How do I turn off DND????
For the NEC DSX DTL-8R-1, try pressing and holding the Volume Down button on the handset for 2+ seconds while the phone is in standby mode. This press and hold option toggles the Ringer Mute feature. It works when an incoming call is ringing or in standby.
The manual for the this phone is available online here: http://www.teamextenda.com/download/nec/NEC_DSX_Cordless_DECT_UserGuide.pdf .
I hope this helps.
Oct 31, 2014 | NEC DSX DTL-8R-1 DECT Phone
My cordless phone in my restaurant is finally had it. NEC wants $300 for a new cordless! If I buy a different cordless made by a different company, will it be compatible with my NEC corded phone?
No, You must use an Nec telephone, thus the price. If you need it on one line only you could connect any cordless phone on the dial tone before the NEC system. This will ring and also you can call out but you will not be able to transfer from or to it and you cannot use any NEC system features.
NEC $279.45 from me gregdownes@verizon.net
Jan 11, 2011 | NEC DSX Systems NEC-780020 DTR-1-1 BLACK...
Hello, I'm trying to set up my Explorer 7 email. It asks for my incoming and outgoing server settings. Where can I find that information. I call the tech support line and got zero help. Thank you.
Hi
Try this
For incoming
imap.yourprovider.com  Port 993 (for example imap.gmail.com)
or
pop.yourprovider.com  Port 110
For outgoing
smtp.yourprovider.com  Port 587 (for example smtp.gmail.com)
Aug 05, 2010 | Microsoft Office Outlook 2007: Windows
Our office has a NEC multiline phone, and line 9 is lit up green, but when accessing it, there is a busy tone, how can I clear that line?
Easiest way is to unplug the system, wait 20 seconds, and plug it back in. If it's still lit, maybe there's no dial tone on the line.
Carl
Jul 06, 2009 | NEC DSX Super Display Phone BLACK
DND causing line to go busy when on call for new incoming callers
Please contact your local NEC dealer and have them program the phone to go to voicemail when in DND or when Busy
Mar 20, 2009 | NEC-1090021 DSX 34-Button Backlit Display...
Apr 18, 2008 | Lands Phones
Lands Phones Logo
50 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
