Question about Xerox DocuPrint P12 Laser Printer
Xerox DocuPrint P12 Lights Just Flash
Xerox DocuPrint P12 Feed and Paper Lights Just Flash when I ask it to print and I have to click the pause/feed button once for each of the two lights to get it to turn each one to turn off and start to print. I have tried changing defaults settings for paper size etc but now no matter what application I am printing from it does the same. It only does it to start any document and once reset it will print the whole document no matter how many pages, and the even if the next document is one page it has to be done again. Every time I print a new doc it does it. please help Warmest regards
SOURCE:
Cindy Jo
  • 74 Answers
SOURCE: My Xerox DocuPrint M750 printer will not print black text but will print colour
This is just a suggestion. I recently bought a Staples refilled cartridge and had to return it because it did not work. When returning it the Staples Rep said that 50% of the cartridges do not work and get returned. This was an astounding amount I told the rep. Means nothing to him but to you, you may need to return the black cartridge if it is or is not a refill and try it out again. Let me know if that works.
Cynthia Charczenko
Posted on Jan 15, 2008
  • 2072 Answers
SOURCE: xerox workcenter c2424 error code 39,014.40;33151
Could be a dirty scanner. Not much to check, it is a lamp issue.
You can try disconnecting the cables to the document feeder and scanner. The one on the right side of the machine, where the power cord, thats is odd to access and tighten often works loose.
Here is the entire documentation troubleshooting procedure, this is from the service manual.
Step Questions and Actions Yes No
1 1.
Cycle power to the system to clear.
2. Did the error recur?
Replace the Complete.
2 1.
2.
3.
3 1.
Are the lamps on?
2. Run the diagnostic test:
Go to Step 3. Replace the
lamp(s).
4 1. Is the scan head in the home position? Replace Replace
Posted on Mar 28, 2008
SOURCE: Help With My Xerox Docuprint P12
Joe Have You Tried Restarting And Leaving To Cool For A Bit?
MJ ADS PACKARDBELL
Posted on Sep 03, 2008
  • 24 Answers
SOURCE: Docuprint c525a only prints first 2 pages of document
Change the paper size in the program you are printing from and delete all paper size changes later than the beginning of the document.
Change it on your default printer and anywhere else you can.
Usually it is asking for different size of paper and will display this on the lcd
Posted on May 26, 2009
  • 2072 Answers
SOURCE: i need feed rollers for a xerox docuprint n2125
google a business called "the parts drop" . They will have what you need.
You can call and talk to Britt. I have done business with them for a long time.
Very good people to deal with.
Posted on Dec 31, 2009
Feeding paper: how to fix the automatic feeding from the tray? I think the printer won't pick up the paper from the tray. we always have to manually feed the paper. How to fix it?
Pull out a paper cassette, lift up the printer and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Dec 13, 2010 | Xerox DocuPrint 203A Laser Printer
Error e6-drum jam docuprint nc60
Check to see that there is no object in the on the sensor, or paper feed path
Mar 09, 2010 | Xerox DocuPrint NC60 Laser Printer
Fuji xerox docuprint c3055dx printe
please check the pick up roller on the unit. maybe it is worn out. if so, please replace it.
Mar 05, 2010 | Fuji Xerox® DocuPrint C3055DX Laser...
"paper "led always blink
make sure there is no paper stuck inside if it is there just remove it.
Oct 20, 2009 | Xerox DocuPrint 203A Laser Printer
I get a series of blinking orange lights and a green pause.
Hi Mike, the paper feed switch doesn't feed paper... it switches the paper source from the top feeder to the bottom tray. Do you have paper in both? How many times does the orange light flash in between the greens? That tells the error.
Jul 14, 2009 | Canon i850 InkJet Photo Printer
MJ ADS PACKARDBELL
Sep 03, 2008 | Xerox DocuPrint P12 Laser Printer
PRINTER PROBLEMS
NECESITO LOS DRIVERS DE ESTA IMPRESORA. FAVOR ENVIARMELOS A DLFNA207@GMAIL.COM
Jul 16, 2008 | Epson LX-300 Matrix Printer
Paper feed problem
You need new feed components. Feed rollers and retard rollers or pads that stop multisheet feeds.
Dec 14, 2007 | Xerox DocuPrint N17 Laser Printer
All leds' are amber and solid... no flashing.
Have you unplugged the printer and retried? Also check for a paper jam.
Jun 19, 2007 | Xerox DocuPrint P12 Laser Printer
Xerox DocuPrint P12 Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
