Sharp copier/printer AR-336
Has error message - call engineer - H5-01
what is this and can I do anything?
  • 145 Answers
Do the folowing to access service mode
enter,the folowing keys Program, Interupt,Clear,Interupt
once the service screen is displyed .enter the number 14 than press the enter key
Posted on Nov 29, 2008
SOURCE:
How to fix a H5-02 code on a Sharp AR-336
input C + interrupt + 0 + interrupt +start +14 +start
Dec 05, 2013 | Sharp AR-C160 Color Copier
Sharp ar 336 copier
remove the fuser unit and clean the thremister, but 1st turn machine off, upon reinstall of fuser enter service mode p*c* and choose 014 to reset the code, if that doesn't work you may need a new fuser
Nov 09, 2013 | Office Equipment & Supplies
Salut je cherche solution par rapport à un code Code H3-01 sharp AR 336
The problem is in your fuser section. You may have a bad thirmistor or heater lamp or the main pcb. Good Luck...
Jan 22, 2010 | Sharp AR-M237 Copier
E7-00
E7 00 Content ICU communication trouble (ICU
detection)
Detail Communication setup error,
framing/parity/protocol error
Cause Slave unit PWB connector improper
connection
Slave unit PWB – ICU PWB harness
trouble
Connector pin breakage of the motor
PWB of the slave unit PWB
Slave unit ROM trouble. no ROM, ROM
reverse insertion, ROM pin breakage
May 01, 2009 | Sharp AR-507 Copier
HAVE A SHARP AR-336 WITH A CODE H3-00 HOW DO I FIX THIS
You can try this it works for older Sharp models.
  1. Press # key
  2. Press * key
  3. Press C key
  4. Press * key
  5. your display will stop flashing H 3, if not re-enter the keys again, some machines are temparmental, when it goes blank
  6. enter 14
  7. press the start key then turn it off and back on, if it comes back with an h code there is a problem with the heat section and will need a service call and probably parts.
  8. good luck
Apr 21, 2009 | Sharp AR-M237 Copier
I have a Sharp AR-336 with an error code of E7-11. How do I turn this error message off?
The E7 can not be "turned off". This error usually indicates a bad laser unit or "shading" problems. You could try cleaning all the glass/mirror components including the white shading strip under the glass - it may help.
Probably need a new laser.
Mar 19, 2009 | Sharp Office Equipment & Supplies
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Ar 336 sharp copying machine code F1-05 please help
If you have a finisher on that unit ,that code is upper limit switch problem. Check to make sure your upper tray is in the right position. Otherwise your either your tab is broken or your led is popped.
Jan 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
377 people viewed this question
k24674
Marvin
Marvin
