Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
I have a barracuda 7200.7 80 Gbytes. The dirve spins but stopped booting. Started making clicking noises. I smacked it a bit a few times. Now, the system doesn't recognize the drive in BIOS at all. I opened the drive to look inside. It still spins ok. The arm jumps every couple of seconds from center to 3/4 outwards making a clicking sound, and a scratching sounds. This lasts for a couple of minutes before the drive motor powers down and the spinning stops. I want to save the data if possible. I Replaced the circuit board from a working HD of same model / specs, but no use. I have about 70 GB data on it which is from the last 18 years.
    Genius:
  • 1,066 Answers
This hard drive is toast and sadly you are half the reason as you never, ever ever open or hit a hard drive.  There are data recovery firms however, they are very expensive.
Posted on Apr 01, 2009
Is Seagate Barracuda 7200.7 80 Gbytes a Sata Hard Drive or not?
Hello and Welcome to FixYa!
Yes this series of Seagate is SATA.
Concerned, Nooh.
Feb 17, 2011 | Seagate Barracuda 72007 SATA 80 GB SATA...
I need the driver of my Seagate Barracuda 7200.7 80 Gbytes Ultra ATA Model: ST380011A Thanks
you might have to physically unplug the disk drive then plug it back in this should activate the found new hardware wizard or
control panel administrive tools computer management device manger scroll to disk drives + to expand if you see your drive right click you will have options update driver ,uninstall,scan for hardware changes,properties in the properties tab you will have more options in the general tab you can troubleshoot, in the driver tab you can update driver,rollback driver,uninstall driver
hope this helps
Nov 24, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
The Seagate Barracuda 7200.10 500 GB SATA Hard Drive External falled and now is not more recognized by my pc Win XP
Hello
OK, you need to let me know if the drive spins up, you should be able to hear it. Also, you need to have a listen if the drive makes a clicking noise.
Please be so kind tom let me know.
If the drive makes a clicking noise the drive is done, you will need to take it to a recovery institution to recover the data.
If the drive does not spin up, the circuit board or the power cable might be broken.
Hope this can be of help.
Kind regards
Andrea
Jun 17, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Timing belt
if you are sure it is your timing belt then i would get it changed before it breaks and causes alot more problems.
working on a honda now noise started and they didn't change and belt broke and bent the push rods
Mar 19, 2010 | 2000 Mitsubishi Galant
Hard disk Not Detecting (Media Problem)
may be comming steps you solve your problem
check your bios settings on first bootable devices
check your ide or sata cable interfacing mother board correctly
check the power connections
also you want check this one is your os faulty,now you make master &sleve and boot anther hard drive
Jun 12, 2009 | Kanguru - 500GB Disk (Black)...
Media test failure; check cable
it seems like a hard drive failure or the hard dirve not seated well. I'm assuming this caz you cannot boot up. Try reseating the hard drive and try again, If still not working, try and listen for any clicking noise from the hard dirve.
Mar 04, 2009 | Acer Aspire 5100 Notebook
Dropped external hd not being recognized
replace the hard drive, as dropping it has rendered it totally useless.  be more careful in the future.
Nov 13, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Speedometer and tach
Make sure you have installed the battery correctly red cable on the (+) and black cable on the (-) side sounds like it may be reversed this wold cause instant battery drain.
Oct 20, 2008 | 2003 Dodge Grand Caravan AWD
My seagate barracuda 7200 b will not boot up. It has been operating fine for the last 8 months
i suggested you use NORTON DISK DIAGNOSTICS to repair the MBR(master boot record)the master boot record is bad and you can use winXP bootable nto repair the drive by pressing R after booting is completed.but you need to be able to use DOS prompt before you can do this
Jan 14, 2008 | Computers & Internet
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
336 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
