1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #1" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a few
hours and try the registration ( II ) again.
NOTE: the base can only handle 5 handsets and will
increment the number of each handset registered
until "Handset #5" has appeared, even if some of
the handsets are lost/not in use. Trying to register
more than 5 handsets will result in "Registration Failed."
III. To clear the base of all handset registrations and
be able to start registering again at Handset #1:
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink.
2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration
3. for multiple handsets, return to II. above and
register each handset in turn.
Good luck !!
1) Turn Off the Phone 2) Remove Battery 3) Remove Sim Card 4) Put battery and sim card again 5) Turn On the phone 6) Press Menu 7) Factory Data Reset (Remember that: This action will reset the phone to its initial factory state, erasing all data and wonloaded applications, so BACKUP BACKUP BACKUP first you try this). Press "reset phone" HARD RESET 1) Turn off the Phone 2) Press HOME + POWER KEYS (keep them holding for about 25 secs) until you see a screen with a phone and a triangle. then 3) SLIDE YOUR KEYBOARD TO OPEN IT 4) press ALT + l ( TO SHOW YOU OPTIONS) 5) Press ALT + W ( TO FORMAT ALL DATA) Note: When I write the sign + you don't have to press the + sign, it means that you need to press both keys @ the same time. Note2: Don't do this if you don't have a Data Plan or your 2G or 3G is not working, why? because you will not be able to sign in again without a working Data Plan (2g / 3g).
you can try pressing the reset button for about 5 sec, and then turn on as normally would. you can also try pressing down the start/pause button for about 5 sec. you may want to wait about 1min before restarting.
All you needs to do is reset the printer by;
Power off the printer Hold the stop/reset button then press and hold power (for 5 secs) Hold Power and release the stop/reset button Press the stop/reset button twice Release power button Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should be orange. Press the power button to set data The press power again to shut down
and then again the restart.
This should reset the print should work.
