Question about LaCie 2-Port eSATA 3Gb/s PCI Express Host Card SATA Hard Drive
Lacie Sata PCI Card not working on MacPro 2x2.8 with OS 10.5.5
No mounting of Lacie Sata HD -works fine with FW 800 - when connected to Lacie Sata 2 3Gb/s PCI Express Card 2E. Lacie drive on LACIE CD-Rom version 1.0 installed according instructions. Another PCI card, another slot, other cable, other HDs (LACIE and WD) still no success. In software update more info I find the PCI card installed in the slot but the mention: NO DRIVER Installed. Installed again the driver from the Lacie CD: no help. Until now no response from Lacie; F Derom Belgium
SOURCE: LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Posted on Jun 10, 2007
  • 42 Answers
SOURCE: help
Take it in, controller may have malf'ed when it got unplugged, been known to happen.
Posted on Dec 09, 2007
SOURCE: Lacie drive won't mount
Ive solved the Whole Lacie wont mount problem.... Thanks to Lacie support center, Best Buy, The internet and several Tech shops I took my crashed lacie d2 quadra 500 GB hard drive to for help when it crashed. They didn;t help and none of the stuff I bought helped either. Here is the solution: Take any of your crashed lacie Hard drives (That are clicking and making a noise to a Windows OS) FOOTNOTE: NO MATTER WHAT ANYONE SAYS, YOUR LACIE HAS NOT CRASHED AND DOES NOT NEED DATA RECOVERY$$$$$$$$ Take it to a Windows (XP worked on mine) install your lacie one button disk, after its installed properly, Run the lacie one button recovery by clicking the blinking and clicking switch on the hard drive the program will come up and show the Lacie Hard drive. Go to windows control panel and run add hardware program and search once. (if it hasnt mounted it will not find it) just let the search go through once and after it says can-not find hardware leave it open. Go to My Computer and open it, keep the window open that shows all of your drives. Wait about 4-8 hours depending on what you have going on (go to the movies or go to sleep) and come back and your lacie drive will be mounted. (THIS IS NOT THE LAST STEP- DONT GET HAPPY YET) This is whats going to burn your attitude to a new level. The Lacie Hard drive is SUPER un responsive. I advise opening just the main window and taking a look at all the folders and files you have on them. ( i solved mine by simply erasing the Video files. Final cut pro cache folders etc.) if you use your hard drive for things like editing video and audio then more than likely your drive is slightly corrupted (don't get angry) this does not mean its trashed, it means that there is a problem with file structure and a single or several files confused the hard drive. Once again your lacie is not trash. I used mine for video editing in Final cut Pro, and Audio in Pro Tools, among other things like saving photos and software, etc... Just take the time to simply delete what you know you dont need.. or even better, format the entire drive and it will be like new. Another step you can take in mounting your Lacie is to download Mac Drive 7, install it on a PC- not MAC, this process WILL NOT work on a MAC (none of these steps will work on a mac- Trust me, not matter what these nerds say, dont believe that it will- its going to cost you.) Install the Mac Drive 7 on a pc, run the Error Check and repair function and it will take about an hour depending on what you have on your drive and how many errors are found. and It will fix the drive. As stated previously - these steps will ONLY MOUNT YOUR DRIVE. Access to the files and folders on your drive will be very unresponsive. Basically if you plan on copying a movie to your desktop forget about it. 30Mb would take about 2 hours. 6Kb took close to 4 mins to copy from the lacie. You wont be able to back it up so forget about that too. Just follow the begining steps and find out what has done this to your Lacie (you know what it is!). As stated previously- I used my LACIE D2 qudra 500 GB Hard drive (that is only 6 months used) for average things like downloading, uploading, saving, etc... the same things you do, Plus I ran Final Cut Pro, Pro Tools, Logic Pro, and a S**T load of other programs on this drive and what confused or "Corrupted" my lacie and made it BLINK, CLICK, and make STRANGE
Posted on Mar 19, 2008
  • 33 Answers
SOURCE: LaCie silverscreen Utilities CD-ROM
The OS is hidden in memory, you can clear all files off the machine and it will still work.
The only requirements are the 4 folders:
Firmware
Movies
Music
Pictures
That's it!
New firmware can be found at www.lacie.com
Posted on Apr 10, 2008
  • 22 Answers
SOURCE: recognized - but no mount
Don't know about the MAC part, but an I/O error implies that the either the source file cannot be read or the destination drive will not write. This is usually an indicator of a bad HDD. To check, I would attempt to connect the external drive to another computer. If it still gives the same indication, contact the drive manufacturer about data recovery recommendations
Posted on May 30, 2008
How Do I exactly make a 500gb sata hdd work with this p4m266a ndmx motherboard? It doesn't appear to have a sata port and using the sata compatible cable did not help. Thanks
if your motherboard does not have SATA, purchase a SATA - PCI card, they cost something to the direction of 10 to 20 $ and give you 2 to 4 or more SATA ports.
Feb 12, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
It wont sync up
Get a Firewire PCI Card that has TexasInstruments (TI) Chipset
Im using Lacie PCI Card and it works perfect!
Cheers
Sal
Jun 18, 2010 | Tascam FW-1884 Firewire Audio / Midi...
Lacie 1 t drive will not mount. previously worked fine for almost two years. used as pc backup drive on bootcamp side of macpro. Primary drive in computer has also failed (fantastic). drive does spin,...
Sounds as though the interface card, between the hard drive and connector panel at the rear has packed up. If it is out of warranty it is worth opening and connecting to a separate cable. You will most likely be lucky.
Mar 07, 2010 | LaCie (300770) 250 GB Hard Drive
FW Lacie Porsche FW ext. HD 250GB light on case blinks and
conect your harddisk to computer whch has windows xp.
Then go to start emnu then type in run 'cmd"
then you can see command propmt.
Then go to your external drive letter like f:
then type 'chkdsk /r"
then pres "y'
then it fix error on hardisk.
Aslo you can format it .
Just take backup of data which you need then right clik on drive licon and format it.then it works fine.
Jun 23, 2009 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Firelite HD 160GB won't mount on PC
Try this site: http://sewelldirect.com/USBManualShareSwitch2To1.asp. Although you must purchase this "splitter", you can use the Hard drive on two different computers. CAREFUL! Make sure that only ONE computer is reading or writing to the same file at a time! If you have a crossover, the hard drive could crash!
Feb 01, 2008 | FireLite (USBFLB80) Hard Drive
LACIE BIG DISK 2.0 USB
You can try by increasing the RAM of ur Machine
Jan 23, 2008 | LaCie 2-Port eSATA 3Gb/s PCI Express Host...
Can't accept Quadra 500 on my owerMac G5 Quad
Scrap LAcie!! Sounds like in this case, it may have been jostled around during shipping. None the less, Lacie drives are nothing more than bricks waiting to fail. Go Western Digital, but if oyu can, zip straight for Seagates!!!! Professional grade!! ALways check the cables, the ones that come with them are bottom bin cables, made by little singapore children with no fingers..... Invest in a good cables...a drive is only as good as the weakest datalink.
Cash on the warranty!!!
Keep me posted.
Dec 13, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 2-Port eSATA 3Gb/s PCI Express Host Card SATA Hard Drive Logo
90 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
