Question about Sharp Office Equipment & Supplies
Error message code H5-01 on Sharp AR-336 - Sharp Office Equipment & Supplies
  • Jill Bayley Nov 27, 2008
    Thank you - didn't realise what p c and * were but program, clear and interrupt then type in code in box - cleared it but unfortunately now another code e7-11 -oops - can you help please?
    Genius:
  • 1,142 Answers
Have u tried to reset the printer if not just unplug the power leave it for 10 mins then reconnect it back and see.
Posted on Nov 27, 2008
  • Maanita Chadha
    Maanita Chadha Nov 27, 2008
    there is a paper piece in the fuse assembly which is jamming take the fuser out you hve to use a screw driver to do that but make sure to unplug the power cord as it can cause electric shocr, for further help please ask.
    Sergeant:
    Champion:
  • 248 Answers
H5-01 is a fuser jam error. Remove jam and reset with sim 14.
  • 2 more comments
  • Paulito Manuel
    Paulito Manuel Nov 27, 2008
    H5-01 is 5 continuous jams in the F-section and requires full examination of F-section and Left door assembly, for root cause.
    It will need Engr/Sim codes to re-set the machine.
  • Paulito Manuel
    P * C * 14 Then 1 For Yes And Follow On Screen Directions, Code Should Clear Out.
  • Paulito Manuel
    H5-01 code is set when there are 5 continuous jams... usually there will be paper wrapped up around the fuser
    roller(s)... Check fuser and reset code....sometimes low fuser heat
    will cause the jams in the first place...make sure the thermistors are
    clean and that the heat lamps are in good working order. Also make sure the picker fingers aren't broken, will cause continual paper jams.
  • Paulito Manuel
    E7-11 is a white level shading correction error. This code was intended
    to identify a dirty white level reference (located under the left edge
    of the copyboard glass).clean the optics, mirrors, and the exposure bulb etc.
How to fix a H5-02 code on a Sharp AR-336
input C + interrupt + 0 + interrupt +start +14 +start
Dec 05, 2013 | Sharp AR-C160 Color Copier
Sharp ar 336 copier
remove the fuser unit and clean the thremister, but 1st turn machine off, upon reinstall of fuser enter service mode p*c* and choose 014 to reset the code, if that doesn't work you may need a new fuser
Nov 09, 2013 | Office Equipment & Supplies
Salut je cherche solution par rapport à un code Code H3-01 sharp AR 336
The problem is in your fuser section. You may have a bad thirmistor or heater lamp or the main pcb. Good Luck...
Jan 22, 2010 | Sharp AR-M237 Copier
HAVE A SHARP AR-336 WITH A CODE H3-00 HOW DO I FIX THIS
You can try this it works for older Sharp models.
  1. Press # key
  2. Press * key
  3. Press C key
  4. Press * key
  5. your display will stop flashing H 3, if not re-enter the keys again, some machines are temparmental, when it goes blank
  6. enter 14
  7. press the start key then turn it off and back on, if it comes back with an h code there is a problem with the heat section and will need a service call and probably parts.
  8. good luck
Apr 21, 2009 | Sharp AR-M237 Copier
I have a Sharp AR-336 with an error code of E7-11. How do I turn this error message off?
The E7 can not be "turned off". This error usually indicates a bad laser unit or "shading" problems. You could try cleaning all the glass/mirror components including the white shading strip under the glass - it may help.
Probably need a new laser.
Mar 19, 2009 | Sharp Office Equipment & Supplies
Ar 336 sharp copying machine code F1-05 please help
If you have a finisher on that unit ,that code is upper limit switch problem. Check to make sure your upper tray is in the right position. Otherwise your either your tab is broken or your led is popped.
Jan 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier/printer AR-336
do the folowing to access service mode
enter,the folowing keys Program, Interupt,Clear,Interupt
once the service screen is displyed .enter the number 14 than press the enter key
Nov 27, 2008 | Office Equipment & Supplies
133 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
