Question about Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony Vega Digital TV model KD-28DX50 U
TV will not switch on. Standby button flashes on and off. Power to TV OK. Remote working OK. Any ideas?
    Scholar:
  • 168 Answers
The symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, vif,sif, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service technician
Posted on Jan 16, 2007
SOURCE:
We have a Sony KD-28DX50 U digital tv. Since digital retune we have no "event information" after channel 27. Worked fine before. Sony 0870 number in a loop by sound of it.
Problem solved. Tele scrapped. Finally found a human being on one of Sony's "help lines" who said, as it is quite old set, software couldn't cope with large number (198) of digital whatsits. Got a nice, and cheap, replacement from Amazon at 8:30 next day.
Oct 20, 2009 | Samsung LN-S4092D 40 in. LCD HDTV
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Vega TV , On off switch
prolly u need the "D" board replaced--common to give error code of 5 to 6 flashes--unplug and wait to reset and try again
Jul 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony digital tv KD 32DX40U wont pick up digital signal
The tv is a 2k model - I have the same one, digital is now 8k so it won't work digitally anymore.
2K Equipment
  • All 2K-only products will stop working with the introduction of the 8K transmission mode at switchover.
  • 2K-only set-top boxes cannot be upgraded, but 2K-only IDTVs can be updated by adding a current set-top box or digital TV recorder.
  • A full list of affected models is on the Digital UK website at www.digitaluk.co.uk/2kequipment.
Jul 08, 2009 | Sony Televison & Video
The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
Can't tune my sony KD-28DX50-U TV into freeview channels
Phone SONY UK digital helpline on 08706 001717 and they will give you the phone number of your nearest authorised SONY dealer to come out and fix the problem free of charge.
Nov 16, 2008 | Televison & Video
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Dec 21, 2007 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Kd-32fs170
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 24, 2007 | Sony KD-32FS170 32" TV
Sony KV-32FS200
I read the manual and it says in the FAQ.
Q- TV doesn’t turn on
after disconnecting
the TV and timer
LED flashes
❏ Press the POWER button on your remote control or in the TV front
panel, one more time.
Tell me if it works...
Oct 09, 2007 | Sony FD Trinitron WEGA KV-32FS200 32" TV
Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
142 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
