Question about Sharp AR-5320 Black and White Copier
My sharp copier AR-5320 just stopped copying and displaying a H
Copier AR-5320 PROBLEM
    Problem Solver:
  • 11 Answers
Check main power supply socket and plug for blown out fuse,if it doesnt work open the cover on the left hand side to access the power supply board check the fuses if blown replace with the same rating.
Posted on Nov 28, 2008
Problem for Sharp AR-5320 Black and White Copier Ar 5516 display H4 error?
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Aug 22, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-5316 device driver for windows 7
5316 copier doesnt work with win7.you should use win xp
Aug 01, 2010 | Sharp AR-5320 Black and White Copier
Dear All We want to but sharp Machine but we ...
5316 ,16 copy per minute
5320 , 20 copy per minute
May 20, 2010 | Sharp AR-5320 Black and White Copier
What difernt betwenn ar 5320 and 5320 e
The AR-5320 comes standard with XY Zoom and Dual Page
Copy Mode. The AR-5320E has additional image editing functions (Rotation Copy, Margin Shift, Edge/Centre Erase, and 2-in-1/4-in-1) available with the optional AR-EB7 upgrade and you can uprade the memory for printer with optional AR-SM5 256 Mb
Apr 27, 2009 | Sharp AR-5320 Black and White Copier
Problem with sharp ar 5320 copier
Sounds like a bad earth or loose connection. Try using the parrallel port instead, or take the panel off and look for bad connection
cheers
Nov 29, 2008 | Sharp AR-5320 Black and White Copier
It dosent enlarge the document in book copy mode in sharp ar 5320
You can not enlarge when set to book copy since the machine is not able to rotate the image to fit on bigger size of paper.you need a machine with rotation feature like the Sharp ar-5127 with a dual function board.
Nov 15, 2008 | Sharp AR-5320 Black and White Copier
Stopped working
try to see if there is a number appearing after u, maybe its u2-40 which is a toner problem since you run it continously. You can check it by pressing the copy button(green) and the sub code will appear. try to replace the toner cartridge and reset the copier by turning it off and on again, hope it helps
Nov 07, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 B & W copier giving F 5 alternatly.
thinksssssssssssssssssssssssssssssssssssssssssssss
Oct 07, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 B & W Copier giving L 4 error msg alternatly
L4 is main motor drive overload. It could be a power problem going on with the copier. Are these copiers plugged into surge protectors?
If you can have a Sharp technician look at it, it would be a good idea to determine if the motor, power supply, or main board is the culprit.
Sep 21, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Black and White Copier Logo
83 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
