Question about D-Link DKVM-2U 2-port KVM Switch
Mouse freezing up
When I switch to my 2ed computer my mouse wont't unfreeze. Can someone tell me why that is and how to solve it. Thanks JoAnn
    President:
  • 2,961 Answers
On your second pc, try this:- Go to my computer>properties>hardware tab>device manager, then look down to 'mice and pointing devices', click on '+' sign, right click and delete. Re-start pc and let windows re-install device, as your mouse drivers may be conflicting.
Posted on Jan 11, 2007
Mouse freezes up right when startup begins
Hi, make sure the drive is right for mouse, update the drive, if problem persists it will be necessary to replace the palm rest ( mouse pad)
Dec 16, 2013 | Toshiba Satellite M35X-S161 Notebook
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Cursor freezing
Remove viruses.
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
Mouse will not unfreeze after i put router on my computer
Take the router off and see if it unfreezes. I doubt that your router has anything to do with your mouse freezing. I would say you might have a virus or infection so run a scan. Also you mouse might be going bad.
Try booting up in Safe Mode and see if your mouse freezes. If it does not, surely a virus or infection is attaching your mouse.
Make sure you are not pulling the mouse out of the computer if the end that goes into the computer's green port is round. The round mouse (PS2/Serial) cannot be pulled from the computer and expected to work unless you reboot.
The Flat USB mouse (the end that plugs into the computer is flat) is a plug and play mouse and can be pulled and reinserted into the computer without rebooting.
Apr 11, 2012 | Computers & Internet
I am just using my computer and suddenly the mouse just freezes and doesnt unfreeze unless i log off or restart
hi,
The issue was possibly related to virus issue, not only the mouse freezes, the delay in keystroke and the application access also will be slow.
scan the machine in safe mode by pressing F8 if your operating systems is XP, with good antivirus.
Oct 23, 2010 | Computers & Internet
Computer keeps freezing no matter what im doing
Check that nothing is blocking the laser if your mouse has one. Even a hair can cause it not to function properly. Download and re-install a custom driver for whatever brand of mouse you have. Try the mouse in another system and see if it does it there.
Sep 23, 2009 | Computers & Internet
Mouse scrolling probalem
I believe you and I had the same problem. I just figured it out, actually by accident!
In MS-Excel, on the top tool bar (File, Edit, View etc etc.) there should be a tab next to the Help tab, called Window.
Click Window, then look through the drop down until you see UnFreeze Panes (Note that the problem will be fixed if you click UnFreeze Panes, if indeed our problem was the same.)
If you do not see that option "UnFreeze Panes" and instead see Freeze Panes... then I haven't the foggiest how to help. -___-;;
Good Luck!
Feb 25, 2009 | IBM Lenovo Mouse 76H6618
Mouse freezes
Hello, it can depend on many things
1. Update your mouse driver (enter the manufacture site, find there model of your mouse, and download drivers for it)
2. If your mouse is not laser (working with ball) open under the ball and clean it.
3. It can be virus or spyis infected your PC. uptade your virus definition and run deep system scan.
4 If your mouse has law bit, you have to change it. (if nothing solve problem do this)
Sep 07, 2008 | Computers & Internet
My Keyboard only works on one PC but the monitor and mouse works on both?
Plug the key board and mouse directly into the computer that doesn't work, let it recognize the hardware and then reboot. After reboot, plug the keyboard and mouse back into the KVM and reboot again. That solved the problem for me. Most likely, the computer that doesn't work has never loaded the driver for that key board and does not recognize the input sent from the KVM.
Oct 09, 2007 | Belkin F1DK102U 2-port KVM Switch
D-Link DKVM-2U 2-port KVM Switch Logo
565 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
