Question about Car Audio & Video
Monoblock amp with DVC subs
Hi I have the most retardedly confusing question that's ever been posed so bare with me here. I have a performance technique ICMB-DIGITAL and I just blew out both my subs. I have a 99 lexus gs 300 which had a stock sub. I want to run a KICKER 07C104 free air in the place of the stock sub, but then I want to try and run a KICKER CVX12 in a box in the trunk just to add some thunder. Is this even possible? My next question is why does a monoblock amp have 2 sets of terminals? Is it internally bridged or something?
    Genius:
  • 1,066 Answers
Is the amp 2 ohm stable, and are the speakers 4 ohms apiece? ohmage is indicated by a number such as 4 followed by the greek letter "omega"
if the amp is 2 ohm stable, and both speakers are 4 ohms apiece, then yes you can hook up both, one to each terminal set
Posted on Nov 29, 2008
Best way to wire 2 12in. 1800 watt dvc subs to 3000 watt monoblock amp
if they 4 ohm speakers and they are rated for 1800 a piece( thats hard to believe )
then parallel them
and you need to ell us if thats the speakers peak power( which it has to be.. )
Now tell us their average power dissipation capability and impedance..
You'll geta safe answer
Mar 13, 2017 | AMP Car Audio & Video
Wireing jl 500/1 to dvc sub
You will have to take a piece of speaker wire and put it from the positive of one voice coil to the negative of the other voice coil.....Then, with the other remaining positive and negative, hook it up to the amp.....And your good to go....If your still confused, get back to me....hope that helps.....
Mar 24, 2012 | Jl Audio 500/1 Car Audio Amplifier
Kenwood x1200m
this amp is 1 ohm stable and a monoblock which means there is only one channel in the amp so if you run both subs parallel at 2 ohms and parallel them together you will be at 1 ohm which this amp will handle excellently. i know this because i have it and have been running it at 1 ohm for the past 2 years with no problems.
Mar 01, 2012 | Kenwood eXcelon X1200M Car Amp
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
I HAVE A JL AUDIO MONOBLOCK AMP 250
there could b allot of factors involving this problem first could and most important is to make sure theres no loose connections in your wiring and find out how ur subs are wired in. are they SVC or DVC (single and duel voice coils) also what are theyre impedences if SVC could be 2, 4, or 8 also the same as DVC but jus 2 sets of terminals. find out first then the reason i ask is cause allot of half way manufactures are installing a device u could say that will cause amps to automatically cut off when the load on the amp reaches its lowest impedence load so when ur subs are moving in and out that load varies with how far the sub is extending out jus cause a sub say its a 4 ohm SVC doesnt mean that when its pounding away the load may actually be 3 ohm when fully extended. find out these variables first and then reply and ill let u know what to do properly.
Jan 16, 2009 | Jl Audio 250/1 Car Audio Amplifier
2 ohm dvc and monoblock sub amp
Yes. When you run two-two ohm subs to a monoblock amp its on the same channel meaning there ran parallel, and that makes it one ohm and most mono-blocks won't read one ohm. Are you popping fuses in the amp?
Apr 02, 2008 | Audio Players & Recorders
Kenwood KAC-9152D monoblock
The amp says it's 1 ohm stable, so assuming the DVCs are dual 4 ohm, you should be able to connect all "+"'s together and all "-"s together, like the picture below:
As for the amp shutting off for a few seconds, it sounds like it's either:
A) Not getting enough power at high volume.
OR
B) Overheating.
The cap on the +12V to the amp should help, but putting a meter on the +12V might tell you whether it's dropping too low (<11V).
When you first turn the volume up, how long does it work fine before shutting off? Is it with the vehicle running or not?
Mar 25, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Bridging to 12 inch kicker competition subs to my 1000 watt alpine 4 channel amp
I'm a bit confused. For Alpine amps, the "M" prefix is for monoblock (aka single channel) amps and the "F" prefix is for multichannel amps. The only M550 I find is an MRD-M550, which is a monoblock, not a 4 channel like you say.
Unfortunately, I can't give you accurate help until we know weather it's truly 1 channel or 4 channel. Then I'll be glad to help!
Mar 05, 2008 | Kicker 01C8VR4 Car Subwoofer
Sub not playing to full potencial
you haave either connected it incorrectly.make sure the ohm of the speaker matches that of the amp ..connect the positive coil to the positive coil at the back of the sub and the same for negative .then run your cables to the amp .you should only have one positive cable and one negative cable .this connection will create a 2 ohm connection make sure the amp can handle that load .prefarably using a 2 channel bridgable amp or 1 channel monoblock
Feb 20, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
Car Audio & Video Logo
158 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
