Question about Mitsubishi VS-5043 50" Rear Projection Television
Vs-5043 Hi,I went from what appeared to be a convergence problem to a HV problem. After replacing the STK packs (which went quite smoothe),I fired up the TV and have sound and tuner only. The 3 guns do not light. What did I do wrong?
    Genius:
  • 1,153 Answers
1. SHORT DETECT SHUT DOWN (PIN 15 OF IC700) CHECK FOR OPEN L902 PART # 351P070010 OFF Q904 C (15 V SUPPLY) ON THE MAIN PCB. 2. SHORT DETECT SHUTDOWN (PIN 15 OF IC700) CHECK FOR SHORTED D913 PART # 264P722010 AND OPEN Z901 PART # 283P039020 (Z905 AND Z900 MAY ALSO BE OPEN BECAUSE OF THIS). 3. X-RAY SHUTDOWN (PIN 55 OF IC700) CHECK FOR A LEAKY D5A09 PART # 264P244030 OFF PIN 6 OF IC5A01. 4. X-RAY SHUTDOWN (PIN 55 OF IC700) CHECK FOR LEAKY D5A21, PART # 264P045040, IN THE BEAM PROTECTION CIRCUIT ON THE MAIN PCB. 5. CHECK FOR LEAKY Q5A03 AND/OR Q5A04 BOTH PART # 260P559050, IN THE HIGH VOLTAGE DETECT CIRCUIT, ON THE MAIN PCB.
Posted on Aug 26, 2007
Mitsubushi VS-5043 Rear Projection,,, Replaced 3 Converrence IC's. Recovered green color. Red color is bowed. Cannot move red crosshais in convergence set up. Is their a way to reset? Could something else...
There are a few low value 1-watt flameproof resistors in the convergence yoke circuits. They typically range from 1 to 3 ohms. An open resistor will cause the respective color to be non-responsive. Also chack that you have the convergence yokes re-connected to the correct connectors on the board.
Nov 10, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs5043 convergence
Your chassis is a VZ3 that chassis should use two STK 391-020 ICs Its an easy repair Mitsubishi usually will not blow resistors when the ICs go out. You can get the replacement ICs at the following link and they provide free step by step instructions with pictures so if you have even basic soldering skills this isa job you can do in about 30 minutes . Heres the link.
http://servicemanuals.vstore.ca/
May 07, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi 61 in Rear Projection
No they are very easy with basic solder skills. you can get replacements aat this link, and they send free installation instructions and provide free tech support to help you do the repair. you need to replace both of them. Heres the link
Apr 17, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Convergence
1) Repair convergence circuit = replace STK IC's
2) Reset alignment with customer controls
3) Internal alignment,if needed.................................T.
PS. Major hand re-solder will be needed when chassis is out.
Preventative,necessary...............
Nov 28, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi ws65909
Yes,but first it is necessary to repair the problem = replace
both STK392-570 IC's.............Then use remote to adjust
convergence............."inside the tv" is called servicer menu = adjust after repair is complete.You can expect to replace IC's
every five years or so.......................T.
PS Try to match your problem thread model # to actual model #
ie. VS-5043 does not match WS-65909........T.
Nov 25, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi 50 in vs-5043
Needs convergence circuit O/h==replace convergence IC's & any damaged/over-heated resistors.re-align as needed.
Oct 01, 2007 | Mitsubishi VS-50502 50" Rear Projection...
Convergence IC
The convergence IC's are black in color with white lettering on them and will start with STK. These IC's will be standing up and be about 2" X3" in diameter. These IC's will also be mounted up against a large metal device called a heat sink. good Luck
Apr 08, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Possible Convergence
I would suspect you have several capacitors drifting out of tolerance as they warm up. When checking for these, also make sure to change The value Of C813 (33uf 16v) To (10uf 50v) if it hasn't been done already. You'll need a technican with a capacitor meter and ESR tester to find the marginal capacitors. I doubt that any of your STK packs (IC's) on your convergence module are defective. I'm also assuming that the tapping with the wooden stick didn't change anything, otherwise a bad solder connection could be the culprit.
Jan 02, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Jun 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
