Question about Sanyo PLC XU35 Multimedia Projector
Buttons not working on Sanyo Pro Xtrax
The buttons on top of the case do not work and there is no response to the remote control. Is the projector locked up in some way or is it broken, Regards Colin
  • sycoscribble Jan 22, 2009
    i've got the same problem. im pretty sure i locked mine from inside the one of the menu options. i clicked on one of the lock symbols and it froze up. cant do anything with it. wouldnt even turn off. after a while i unplugged it, and now it wont even turn back on.
Gand ma nakh.
Posted on Nov 27, 2008
Connecting sanyo pro xtrax multiverse projector to a Macbook pro
VGA to HDMI cables don't work. They're a con. VGA is an analogue signal. HDMI is digital. It's not possible to convert from one to the other with just a bit of wire.
Sep 02, 2014 | Sanyo PLC-XU101 Projector
Sanyo PRO Xtrax Multiverse Projector powers on but no reflection appears
broken lamp?? check for little cracks in the bulb bar.
If lamp is discoloured( dark grey), overheating is cause, no cooling after using the PJ.
Sep 25, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo Pro XtraX Remote Code
You may have reassigned the projector/remote control codes. If you still have your User's Manual, reference page 38 and there are instructions on how to reset the codes.
If you don't have the User Manual, it can be downloaded at
Please let me know if you have any questions.
Good Luck!
Aug 11, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Connecting a laptop and Sanyo Pro xtrax
Hi Mike4398
Have you tried a PC ( VGA ) Cable yet ?
If you have and there is still nothing on your Projector - do the following :
Right click on your desktop and go to properties , then select settings and check if your Notebook's resolution is supported by your Projector i.e. XGA ( 1024 x 768 ) or SVGA ( 800 x 600 )
Then check if your secondary screen is activated ( it will read attached ) Once this is done close the window and hold down the Fn ( function ) button which is located just left of your spacebar and in your F-row of buttons the one with a screen on it ( differs from brand to brand )
This should do the trick !
Apr 25, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo Pro Xtrax Projector
not all computers are F4 - some are F7... - If there is not a small graphic on each Function button - just press and hold your function button and I'd start with F3 then F4 then F5 and so on - often your image will appear on the projection screen and disappear from your laptop - just re press Function and the appropriate key - you may also need to change your display - go to your control panel then display then settings and you will want 1024x768 - as far as cables you will need a male VGA that will plug into (usually blue) connection on your laptop and then depends on what type of projector you are using - it may take a VGA or RGB (5pin cable ~ red green blue horizontal vertical) make sure that in your menu settings that you have it set to the same as the input you have plugged into
Jan 19, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo pro xtrax
I am not understand the exact problem.
Can you pls explain briefly about your problem?
Dec 07, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo pro xtrax projector
listen im a comp wiz on the remote press video 1 egt. if that doesn't work trash it
Sep 20, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC XU35 Multimedia Projector Logo
599 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
