Question about Mitsubishi HS-U775 S-VHS VCR
VHS-C Adapter Stuck and E4
PROBLEM SOLVED; JUST POSTING FOR GENERAL INFO I bought a Lenmar VCA38 motorized VHS-C adapter and the first time I put it into my HS-U775 with a tape in it, it got stuck. I took the cover off the VCR and after cycling the power and eject buttons several times could not see what was wrong. There just seemed to be something hanging it up on the front left (as you face the VCR). I was finally able to see that the erase-protect sensor was hooking the bottom of the lip of the recess for the erase protect tab on the adapter. Once I was able to hold this back (had to pull the faceplate partially off to get past the flipping door) the tape then was able to eject. I've since covered the recess with duct tape and the adapter now loads and ejects without a problem. Also, when I put the VCR back in the entertainment center and plugged it in, it was flashing E4. Per another post here, I just held the power button for 8 seconds and it went away. All is now well.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Check the tip in my profile
Posted on Jul 18, 2010
I'm trying to install netgear n300 wireless adapter model #WNA3100 and it is stuck on "detecting adapter" what do I do!
How about telling us what is stuck?
And posting the same thing twice does not get a faster answer!
May 05, 2014 | Computers & Internet
Tip
How to eject a stuck vhs tape.
I will show you how to eject a stuck vhs tape. I did this on the sony slv-d300p first, unplug it. Next, take out all the screws on the back. Take off the cover. Locate the loading motor on the right. Turn the gears next to it. After about 5 minutes, the tape should eject. While its open, take a CLEAN piece of paper, hold it up to the drum, and rotate it with the paper against the back. after 5 minutes, take the paper off and stop spinning. the paper may be dirty. put the cover back on, and try to put in a vhs c adapter with NO vhs c in it. when you put it in, it should spit it back out.
on Jul 15, 2010 | Televison & Video
HI is this device battery powered? the one lever prevents it from being taken in by the VCR
The lever sticks out because you have not put a VHS-C tape in the adapter, or because the tape has not been laced up. There is a single AA battery in the adapter to power the motor that laces the tape.
Dec 09, 2010 | JVC CP6U Adapter
I bought a panasonic cassette adaptor for my vhs-c tapes . it says svhs adaptor on the front of the box .will the ordinary vhs-c tapes fit in it and does the door open on the front or is it loaded from the...
You don't specify the adapter you have, but most load from the top. The main thing here is that VHS and VHS-C are both the same size of tape. Whether they are recorded in SVHS mode or not will not affect the adapter, just whether or not you get a picture. Theadapter only allows you to put a compact cassette (VHS-C) into a standard VHS VCR. The adapter will require batteries to allow it to place the VHS-C cassette tape into the proper position for use in the VCR.
Dan
Nov 24, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Doesn't seem to have a battery in the adapter - hard to insert tape then it does nothing
You must first put on the battery so that the mtor reurns back to the return mode so that the VHS-C can be placed . Once the door is shut after placing the cassette, the tape is wound up and it becomes just like a regular VHS tape. Now if this is not happening there is always a small gear on the back side with which you can manually wind to bring it up to the desired level. If not the motr is stuck or the pulley is running loose. You can open up and check inside , it is a simple mechansim with a switch to activate and return. Check the motor and gears. reset the drive by removing, check the battery voltage to the motor and your adapter will work. hope you check this out. Good day
Jul 18, 2010 | RCA VCA115 VHS-C Adapter
Want to use jvc camcorder as webcam
I have just solved this problem for video - not checked audio as using it for stop frame animation. Just bought a USB Video adapter - Easycap and used the JVC Everio DV mini jack to red white and yellow phono into usb via adapter, install software and off you go. I bought a really cheap one to check-Under £10 new on ebay, also S video compatible. Perhaps a more expensive adapter may give better quality image, can also now transfer old VHS from videoplayer to PC-
Also possible to buy an internal capture card.to slot into your motherboard if you are up for that.
Scotty
Sep 02, 2008 | JVC Everio G Camcorder
Error message E4 and stuck tape
Yes with care. Simply remove the cover and with care unwrap the tape. If you must break the tape - but make sure all residual tape is cleanly removed. Re assemble and put a tape head cleaner through- following the instructions.
Jun 22, 2007 | Mitsubishi HS-U445 VHS VCR
Mitsubishi HS-U775 S-VHS VCR Logo
270 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
