Question about Nokia 2125 Cellular Phone
How do you replace the sim card on a nokia 2125?
We have removed the back casing and the battery and opened the flip hatch at the bottom of the battery cavity, but can't see a sim card or evidence of other movable parts to access any other areas of the phone. How is the sim card replaced?
The problem is that the 2125 is a CDMA phone and doesn't use a sim card. You can slide a sim card onto the inside of the metal casing that flips up but the phone lacks the components to reach the metal terminals on the sim card and thus read the sim card.
Posted on Dec 14, 2008
Water damage
1. Remove the back cover of your phone. To do so, you will have to press down on the silver latch while sliding the cover off toward the top of the phone.
2. Remove the battery from inside of the phone. Be sure to place it somewhere where it will not be damaged. Locate a silver hatch; this is where the SIM card is stored.
3. To undo the silver hatch, slide it in the direction that says "Unlock." Then, flip it upwards so that only one end of it remains attached to the BlackBerry. Carefully remove the SIM card.
4. Replace the SIM card after a few seconds. It should fit back into its place in the exact same way you found it. Lock the silver hatch by laying it back down over the SIM card, and then sliding it the opposite way you had unlocked it before (to the side that says "Lock"). Put the battery back in as well (by fitting one end at a time). Replace the cover (make sure the silver button latches).
5. Turn the phone back on. The "SIM Card Error" message should be gone.
Aug 17, 2012 | RIM BlackBerry Curve 3G 9300 Cell Phone
Insert sim nokia 2700c-2
Hi
Always switch the device off and disconnect the charger before removing the battery.
The SIM card and its contacts can be easily damaged by scratches or bending, so be
careful when handling, inserting, or removing the card.
1. Press and slide the back cover towards the bottom of the phone, and remove it (1).
2. Remove the battery (2).
3. Insert the SIM card into the holder with the contact surface facing down (3).
4. Insert the battery (4), and replace the back cover (5).
Remove the SIM card
Press the release spring (1), and slide out the SIM card (2).
Jun 25, 2011 | Nokia Classic 2700 Cell Phone
Screen says Please insert SIM card
A SIM card is a little chip, size of a thumb nail, used to identify yourself as a valid customer of a phone network. If you do not have one, you need to buy from a phone service provider first, your mobile does not allow you to make phone calls without one.
The SIM card must be installed in your phone, for the A767 you have to open the lid on the back, remove the battery and slide it into a slot in the upper left corner of the battery compartment. The contacts of the SIM should face down, the little triangular clipped off corner should be on the right, bottom side when you put it inside.
If you purchased a SIM before already, and installed it properly, it may got loose in its little hatch, e.g. by rough handling. Make sure the SIM card is properly in place (proper orientation and still all way in its slot).
The SIM card may also got dirty or liquid may have entered the phone case. In this case, remove the SIM, carefully clean it and the inside of your phone, reinstall and retry.
Oct 24, 2010 | Samsung Propel A767 Cell Phone
REMOVING MOTHER BD.
wow. okay. start by removing the battery. then unscrew and remove any faceplates on the bottom of your laptop. i.e. ram hatch, wireless card hatch, harddrive hatch, etc. not all laptops have hatches.keeing the laptop upside down on a flat sturdy surface, begin to remove all screws on the bottom, making sure to organize them and mark down or take notes of where they were in a log. make sure you constantly touch a metal case or large metal object of some sort to discharge any static. once the screws from the bottom are removed, flip the laptop over. open the screen all the way, so its flat or almost flat and pry up the faceplate that is abov the keyboard and below the screen. this face plate has cheep japanese tabs so be sure to remove it carfully but firmly. now you have access to the keyboard screws. remove the keyboard screws, taking note of thier location and remove the keyboard. the keyboard will have a long cable like looking thing attaching it to the motherboard. remove it properly. set the keyboard aside and begin to remove the remaining screws that you can find that attache the plastic case to the motherboard or internal components. note thier locations and organize accordingly. when you get this far comment back and let us know okay?
Jun 04, 2010 | HP Hewlett Packard Pavilion DV9000Z 17"...
How to inser simcard in nokia 2680 slide
I can't get the aim card out! It won't slide or flip up or anything, I even put a knife under it and tried to jam it open. How can I get it out without damaging the phone?
Feb 23, 2010 | Nokia 2680 Slide Cell Phone
How do I replace a SIM card in a Nokia 2115i?
firstly turn off your phone then open the battery back cover which easy just slide then take out the battery and you will see the sim card holder take out old sim card and put new sim card then put battery back and put back cover.
Dec 30, 2009 | Nokia 2115i
Sim card
If you remove the battery cover and the battery, the SIM holder is right at the bottom of the phone - it is a little hatch that you have to swing up after pressing up the latch at the bottom.
Jun 30, 2009 | Nokia 6085 Cellular Phone
How do I remove the battery and put the sim card in my new nokia 2760 cell phone
These are steps from the Nokia 2760 manual found at :
http://nds1.nokia.com/phones/files/guides/Nokia_2760_UG_en.pdf
(pages. 12-13)
1. Press and slide the back cover toward the top of the
phone to remove the cover .
2. To remove the battery, lift it as shown
3. Carefully lift the SIM card holder from the finger grip
of the phone, and open the flip cover
4. Insert the SIM card, so that the bevelled corner is on
the upper left side and the gold-colored contact area
facing downward.Close the SIM card holder, and
press it to lock it into place
5. Insert the battery into the battery slot
6. Align the back cover with the back of the phone. Slide
and push it toward the bottom of the phone to lock it
Apr 14, 2009 | Nokia 2760 Cellular Phone
Nokia n70
Hi
all you have to do is to open the back of celpon open the battery! then you can see the sim slot. then insert the sim card.
Thanks!
Dec 14, 2008 | Nokia N70 Cellular Phone
I don't know how or what to open in the Nokia 2125 to change the sim card. We have removed the battery and flipped up the casing at the bottom of the battery cavity, but cannot see any other movable parts...
Nov 27, 2008 | Nokia 2125 Cellular Phone
Nokia 2125 Cellular Phone Logo
265 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
