Question about Nokia 2125 Cellular Phone
I don't know how or what to open in the Nokia 2125 to change the sim card. We have removed the battery and flipped up the casing at the bottom of the battery cavity, but cannot see any other movable parts or evidence of the original sim card that we are wanting to replace.
The problem is that the 2125 is a CDMA phone and doesn't use a sim card. You can slide a sim card onto the inside of the metal casing that flips up but the phone lacks the components to reach the metal terminals on the sim card and thus read the sim card.
Posted on Dec 14, 2008
My nokia x2-00 came out of the washing machine and has some moisture on the inside. have removed the battery, sim and memory card. pls help
try putting both thumbs on back panel and push in one direction try all four direction's one at a time the panel will slightly move now grab the edge sticking out and wiggle loose do not force it will come loose don't get frustrated, if not working put it down and do something else for one minute then try again this panel can drive you crazy. good luck
Aug 26, 2012 | Nokia Cell Phones
How do you remove your sim card from the 6700 slide to replace with new?
I don't have this particular phone, but generally the sim card in under the battery. Before you start, make sure you have all your contacts and stuff stored on the phone, not the sim, or it all goes bye-bye when you change the sim. Snap off the back of the phone. Don't pry the battery out. Usually you have to look for 2 tiny little "latches" that hold it in. Sometimes there is a lever that you push to release the battery. Then you can see the sim card. Sometimes you release a little metal clip that holds it down. On other phones, you just slide the card out from under the metal holder. Pay attention to which way the card is turned, and don't put the new one in upside down. Then reassemble the phone.
Feb 01, 2012 | Nokia 6700 Slide Cell Phone
All telephony functions, including emergeny call are disable due toa communicatio eror
Basically the solution is to claim the warranty and Nokia replaces a new one for you, what if you are out of warranty, just someone like me? Nokia has no answer for that, thank you Nokia ;)
I was thinking "Sim card icon and communication error", maybe it is sim card slot issue? I don't know, but here's what I try -
0. Switch off N9001. Open up N900 case at the back(battery part)2. Take out battery3. Take out sim card from the slot, clean it4. Put the sim card back to the slot5. Tighten the slot6. Take the toilet paper, yes I say toilet paper because it was on my desk when I was trying to fix this7. Try to tear the toilet paper and make it thicker by layering them8. Make the toilet paper slightly same size(square) as the sim card slot9. Put the toilet paper on top of the sim card slot and push in a bit10. Put back your battery and press it little hard, the toilet paper will be underneath11. Close the case12. Switch on your phone
The phone works automagically, don't ask me why, it's really high tech fix if you ever encounter this issue.
Jan 03, 2012 | Nokia N900 Smartphone
My E63 is offline and i don't have money to pay someone to open line it that's why i just used internet
Ok here, first of all Remove back cover,Battery and sim card.Secondly clean the SIM CARD case and SIM CARD with cotton.Thirdly insert other Sim Card and try. I the problem still persist, There is no other solution without spending money.Thanks for visiting fixya.GOOD LUCK
Aug 27, 2011 | Nokia E63 Cell Phone
I don't know where to put the sim card in noki cell 5125?
The sim card slot should be at the back of the phone. Remove the battery and you can see the slot there.
To remove the battery:
1 Press and hold the button at the top of the battery. 2 Slide the battery toward the bottom of the phone. 3 Lift the battery off the phone.
Jun 29, 2011 | Nokia 5125 Cellular Phone
Nokia c7 sim card removal i don't now how ??
Insert the SIM card and battery
Important: Do not use a micro-SIM or a micro-SIM with an adapter in this device. This device does not support use of micro-SIM cards, and use of incompatible SIM cards may damage the card or the device, and may corrupt data stored on the card.
Follow the instructions carefully, to avoid damaging the back cover.
Safe removal. Always switch the device off and disconnect the charger before removing the battery.
1 Unlock the back cover release latch, and lift the back cover
2 If the battery is inserted, lift the battery out.
3 Insert a SIM card. Use the diagram printed on the device to correctly align the card.
4 Line up the contacts of the battery and the battery compartment, and insert the battery.
5 To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Nokia C7 (8 GB) Smartphone
How can i remove my sim card to my nokia c7?
The SIM card is located beneath the battery pack. You must release the back cover latch, lift it up, remove the battery pack, and, then, access the SIM card slot. Please, refer to pages #8 and #9 of your phone's user guide (which you can download from this location, in case you happen to miss it) for further details.
Hope you are able to sort your problems out soon.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
May 11, 2011 | Nokia C7 (8 GB) Smartphone
How do I remove the battery and put the sim card in my new nokia 2760 cell phone
These are steps from the Nokia 2760 manual found at :
http://nds1.nokia.com/phones/files/guides/Nokia_2760_UG_en.pdf
(pages. 12-13)
1. Press and slide the back cover toward the top of the
phone to remove the cover .
2. To remove the battery, lift it as shown
3. Carefully lift the SIM card holder from the finger grip
of the phone, and open the flip cover
4. Insert the SIM card, so that the bevelled corner is on
the upper left side and the gold-colored contact area
facing downward.Close the SIM card holder, and
press it to lock it into place
5. Insert the battery into the battery slot
6. Align the back cover with the back of the phone. Slide
and push it toward the bottom of the phone to lock it
Apr 14, 2009 | Nokia 2760 Cellular Phone
Nokia n70
Hi
all you have to do is to open the back of celpon open the battery! then you can see the sim slot. then insert the sim card.
Thanks!
Dec 14, 2008 | Nokia N70 Cellular Phone
How do you replace the sim card on a nokia 2125?
Nov 27, 2008 | Nokia 2125 Cellular Phone
Nokia 2125 Cellular Phone Logo
78 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
