Question about Hoover Washing Machines
The problem with my washing machine is that the drum does not turn at all. and the timer doesnt work properly
  • 244 Answers
Have u checked the carbon brushes on the motor if these are too low then the timer will seem to have a fault with it has the timer only gives the washer so much time to empty and spin
Posted on Nov 29, 2008
Washing machine won't spin, drum is turning when washing.
The timer unit needs to be replaced. the timer is the dial you turn to set the machine to wash.
Dec 21, 2014 | Neff Washing Machines
My Hoover500MB washing machine sometimes doesnt agitate or spin but will empty and fill
99% of those problems are with the lid switch. Check make sure it is functioning properly.
Oct 03, 2012 | Washing Machines
Drum wont turn
hi take the back off the washer the belt might have snapped if the belt is ok the other fault could be the brushes on the motor 2 black plastic blocks sit either sid e of the motor these are made of carbon and wear down can stop the motor working hope it helps
Nov 23, 2011 | Bosch WFMC 3200 Front Load Washer
Machine will wash but not drain or spin.
machine wont spin while it has water in my advice is to lay the drain pipe level with the floor (outside of your house) so it can drain if it doesnt drain then you have a blockage anywhere from the drum outlet into the pump to the watse pipe if it does drian then take the pump apart and check it turns freely
May 30, 2011 | Washing Machines
Washer will nolt go in to spin after water is pump out...can get it to work if I look safty on.. and spin tub by hand and it will start to turn...
if you can hear the motor trying to start the drum spinning you might be able to do that. if your not hearing the motor trying to turn the drum, then there is something wrong in the timer switches. This timer switch is not all that difficult to replace if you get the proper and exact replacement part
Mar 11, 2011 | Washing Machines
My hoover galaxy washing machine stops when clothes are not balanced properly.i have to even out the clothes then start the machine.if the clothes are balanced it finishes its cycle.if not the machine...
It is normal for the drum to sway excessively and hit the balance switch if the load is not evenly distributed around the drum or if you have excess cloths.
Once the balance switch is trigerred, you can reset by openning and closing the door. It is a safety mechanism which stops the spin cycle if the drum sways excessively.
If this tends to happen often, then you need to make sure the machine is properly balanced and not leaning too much to the back.
Also the drum suspension rods do tend to wear out over time and loose their firmness, causing the drum to sway excessively. You can check this by opening the lid. Pushing down and from side to side onto the agitator, and seeing if their is a firm bound on the drum. Also making sure the drum returns to centre position. If the suspension springs feel loose and wayward, then they will need replacement.
Nov 08, 2009 | Washing Machines
Dial turning round, red light flashes 11 times
The timer must be replaced in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Washing Machines
Hotpoint WD61 stops near start of wash cycle
all in the timer. but there may be nothing wrong. sometimes in the cycle there will be a gap between water full and agitate or between drain and spin depending on settings. try it again and let it go and if there is a gap of more than 5 minutes than it needs a timer. most machines timers are right around $75 and you can most likely replace it yourself. sears appliance parts is the place to buy it. you can order it and they will deliver it to your door. or if you can get the phone # most of the outlets have a parts dept. also they take parts back for full credit for any reason.
Mar 05, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Washing Machines Logo
35 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
