Fabric softener usage on quickwash
We have a Bosch Maxx WFL2260 and use the quickwash cycle quite a lot. We have noticed that it doesn't pick up the fabric softener out of the dispenser on this cycle. Is this a problem or a feature of quickwash?
    Genius:
  • 1,028 Answers
Most likely normal operation .. try a normal or heavy cycle if it works there consider it normal operation
Posted on Nov 27, 2008
Bosch Maxx softener dispenser full of water at end of cycle
it seems that there must be a blockage in the siphon tank softener.
Remove the drawer and wash well, remove the siphon softener (just pull up)
Dec 22, 2013 | Washing Machines
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
It spins, but doesn't pump
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
It doesn't spin or pump
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
Just bought secondhand bosch wfl2260 need to know of 3 fill slots which 1 is for soap and which 1 is for fab conditioner and which 1 is for pre wash
this will help you: http://www.scribd.com/doc/49163596/manual-wfl2260
(check page 16)
DispenserI:(right)
Detergentforprewashorstarch.
DispenserII: (left)
Detergentformainwash,soakingagent,softener,bleachorstainremover.
Dispenser(flower icon)
Cleaningproduct,e.g.fabricsoftener,fabricconditioner
May 28, 2011 | Washing Machines
I have a Bosch Nexxt washer, model number WFMC 32000C/01. Yesterday I noticed the fabric softener was still in the dispenser after the cycle was completed. I cleaned out the dispenser and ran another...
Could be the fine holes in upper dispenser are blocked. Remove soap dispenser drawer and use a washing up brush to clean upper dispenser, replace drawer & test. If not could be upper dispenser or inlet valve.
Jan 10, 2011 | Bosch Washing Machines
Fabric softener dispenser fills up with clear water after washing cycle is complete. I do not use fabric softener .
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
Feb 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Need instruction manaul for bosch wfl 2260
Programmes appear to be taking excessively long time to complete even with the quick wash button pressed - 2 hour 15 min for 30 Cotton wash cycle. Is this right or is there a fault? 30 Easy-care seems to be taking almost as long.
May 17, 2009 | Bosch Washing Machines
Bosch Maxx Washing machine WFL2260
On most washers, this usually means, end of prog, and you should be able to remove washing.
plz rate my comments.
TYhankyou.
Jan 21, 2009 | Bosch Washing Machines
Washing Machines Logo
222 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
