Question about Denon AVR-2803 Receiver
Receiver requirers replacement of blown out put transistors
Only pasifying myself with a yamaha 6.1 that i purchased , because i
absolutely refuse to pay the absurd repair quote /fee that a retailer
gave me. all the while feeling screwed because i had just had this retailer replace the out put speaker jacks that i may had over tightened. anyway the unit was working great and right after i have returned a puff
of smoke comes out it, i contact them regarding faulity repair. i was
just blown off. this was not happenstance. PLEASE GIVE ME A REPLACEMENT quote on these 2 out put transistors. By the way that
retailer is now going out of business . Karma?
techman
  • 3130 Answers
SOURCE: Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Posted on Jun 05, 2007
  • 979 Answers
SOURCE: Denon AVR-3000
First, check your balance control and make sure that it is centered. Next, you might have anything from a bad output relay or fuse to a bad driver/component...accordianman
Posted on Oct 25, 2007
robotek
  • 1512 Answers
SOURCE: Potentiometer and output transistors
Try sony for the transistors, they use them too, but expect a handling and delivery charge from all suppliers these days. It sounds like a standard 330 ohm preset pot by your descriptions. There are more than a dozen varients to chose from. You will need to compare the lead setup and pitch to get the correct replacement. I use Farnell electronics to mix and match odd replacements. Good luck
http://www.farnell.com/
regards
Graeme
Posted on Feb 19, 2008
SOURCE: Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
Posted on Aug 06, 2008
the q guy
  • 393 Answers
SOURCE: fuzzy sound from front speaker
you have a small short in the connection of the unit.. it may be just bulid up which can be fixed by just blowing compressed air thru it. but if it more than that take to a repair shop as it could be an intenal problem
Posted on Apr 27, 2009
I have yamaha htr-5990 it only has 6 ohms to 8 ohms I just bought some Bose 401 there 4 ohms will this work or will it wreck receiver or sound bad
If you want blown output transistors then connect your 4 ohm speakers. Swap them for some 6 to 8 ohms. You can go higher with ohms, say 16 ohms, but NEVER lower than rated.
Mar 12, 2017 | Yamaha Audio Players & Recorders
Yamaha rx-v565 wont turn on. Not "Click Sound" when Press On Button
It sounds like the output ic and or transistors have blown and need replacing. Did you short the speakers or cables?
Dec 01, 2016 | Yamaha Rx-v565 Receiver
My 2 front surround speakers on my Yamaha HTR-6040 quit working. Any suggestions?
Look at the amp for disconnected wires. If OK then the amplifier may have blown output transistors.
Jul 10, 2016 | Yamaha Htr-6040bl 5.1-channel Digital Home...
Yamaha no power
you need to check the power supply input of your amplifier using a multimeter set your tester into a dc voltage reading.then measure the power input you must have a DC voltage supply reading..open the cover check the fuse an open fuse will turn the unit to no power.there are causes of blown fuse a shorted power transistor at the circuit will blown the fuse you need to replace faulty transistors before putting up a new fuse...check also the diode at the power supply section ,faulty diode could lead to the same problem..
Sep 30, 2011 | Yamaha P-2500 Amplifier
I am getting no sound out of the unit
have you tried using different speakers??if so, that your power amplifier transistors are blown with your sound IC (STK).
try replacing these and that should solve your problem
Thanks and good luck.
G..
Jun 29, 2011 | Yamaha Audio Players & Recorders
RX-V2600 HAS BLOWN FUSE CB5 10A 250V REPLACED NOW RECIEVER WILL CLICK THE RELAY ON THE OFF ANY SUGGUESTIONS WE CHECKED ALL OUTPUT TRANSISTORS
check the DC converter and associated transistors. an overload may have taken some out, and rendered the unit useless.
Jun 11, 2009 | Yamaha RX-V2600 Receiver
RX-V800
if you can identify whats blown what ic or pcb board. you can get it replaced through yamaha. or many other various used reciever parts lists online. If you wanted to identify the transistor thats blown find it online and just resolder that one you could do that. But id say try and look into a replacement of the board. if you shorted the poles, then there will be a lot more damage on that channel then the amps final maximizer, or amp as you refer to it. -Thanks Nate
May 17, 2008 | Yamaha RX-V800 Receiver
Sony home reciever
If the problem was blown "output transistors" expect a cost of about $6-$8 per transistor (there are 4 total in the receiver) plus a few bucks for an emitter resistor and perhaps $2 each for the driver transistors (4 max per receiver). Also add in the local labor rate.
Please note that these are estimates and that additional parts may be required depending upon how smoked the output section actually is.
Dan
Mar 25, 2008 | Audio Players & Recorders
Denon AVR-2803 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
