Question about HP Compaq nx9010
Screen Problem... I have a HP Compaq nx9010 Notebook and from time to time the screen gives me problems: the screen gets divided horizontally with the bottom half "frosting"... in other words it fades to blank but in a off-white color, I then have to adjust the screen a few times before it returns to normal again, also, this problem occurs when the screen is bumped or adjusted. Sometimes the top quoter of the screen does the same but at the same time flickers in random thin bars/stripes horizontally - again the screen needs to be adjusted in order for the screen to return to normal. I've also found that I need to hold the screen by the hinges while adjusting the screen to get it to return to normal. the last bit of this problem is when it boots, the screen is gray with two thin vertical lines on the left hand side of the screen - one being red and one being green... this sometimes goes away when the O/S welcome screen appears but from time to time it stays and need to reboot a few times before the screen returns to normal.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 167 Answers
I had a similar problem with one of my laptops, there is a ribbon cable that connections the LCD screen to the board inside the laptop case that gets a little loose. In my case it was a easy fix because the button panel on my laptop popped right out and I could take the end of a pencil and push the connector back down into the socket; not all laptops make it that easy for you. If you laptop is still under warranty I would make HP fix it; there is also a chance the LCD screen could be burning out.
If you're not squeamish about fixing it yourself my recommendation is do the work at your own risk. The only hard thing about taking apart a laptop is putting the each screw back in the original location; many laptops have more than 5 different sized screws holding it together. Furthermore, you don't need to dismantle the whole thing; worst case there are 2 - 4 screws that hold in the keyboard and 2 - 3 screws holding in the forward button panel. Near each screw hole is an indicator what it is for; on my laptop it shows the letter "K" to represent the keyboard screw holes. I'd usually stay away from taking out the screws from the 4 corners of the laptop...
If your keyboard has a trackball there is a mini ribbon that is fragile connected underneath, so after removing the keyboard screws be careful not to pull farther then the slack allows.
If you're lucky you won't have to monkey with any of this and the forward button panel will just pop out. Laptop designers are making it easier to "replace" laptop screens and keyboards because it is a common problem. I'm positive if you're able to secure that connector you won't have that "frosting" effect you see now.
If you have anymore questions just let me know...
Posted on Nov 27, 2008
How to dismantle hp nx9010
No problem, rigidarmz!
HP Support > HP Compaq Business NX9010 Notebook PC > Main Support page,
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=321850&lang=en&cc=us
Go down to the subheading -
Resources for HP Compaq nx9010 Notebook PC
Click on Manuals under this subheading.
Scroll down to the black bold subheading -
Service and maintenance information
Click on the file name -
Service Manual
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds, before the first page comes up.
(10 seconds just now using a medium speed DSL connection)
May I ask; anything I can help with?
Post in a Comment.
Regards,
joecoolvette
Oct 14, 2012 | HP Compaq Business Notebook NX9010
Screen on compaq nx9010 is darkly,barely visable, machine works otherwise. Restart and no problem (yet?) Is this the ballest going out? Is this circuit part of the motherboard or on a separate circuit...
1) Is of all we will go to BIOS screen and check if we get the same screen.if that the case then we need to take the laptop for repair
2) we will go and install the upgraded graphic driver
3) we can try doing system restore
4) we will go and do recovery
Dec 13, 2009 | HP Compaq nx9010
Writing on behalf of my brother; his hp compaq nx9010 wont load past the windows loading screen the screen goes grey and stays like that very rarely it loads up after a while. if i trid to start up into...
hit f8 at startup, choose enable VGA mode. After boot, download the new driver for the ati video card and install it. You can go to the hp website and download the video driver there.
Mar 21, 2009 | HP Compaq Business Notebook NX9010
Monitar drivers
Here is general download page for your laptop, you will also need to install network driver and audio drivers :
HP Compaq nx9010 Notebook PC - Download drivers
here is video driver :
» Driver - Graphics » Driver - Graphics - Intel
Try both, as 9010 is built in two different versions.
Please vote the solution.
Many thanks.
Aug 15, 2008 | HP Compaq Business Notebook NX9010
Replacing the screen on my HP compaq NX9010 laptop
give your email and I'll send you service repair manual for ur model
Mar 03, 2008 | HP Compaq Business Notebook NX9010
Hp compaq nx9010 notebook pc
lol ;) Much harder than with a pc.
But you need to remove the battery for it. I am afraid it would require taking the keyboard out.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00246219/c00246219.pdf
here is the manual to help with the process.
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
HP Compaq nx9010 Logo
226 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
