Question about Coleman Mach III Air Conditioner
We have lg air con, i think it is a split system. no buttons visiable. we lost the remote for it a while ago. it turned itself on an hour ago. cannot find remote want to know how to turn off?!
    Problem Solver:
  • 13 Answers
Find the circuit breaker of this aircon outlet or unplug the unit to outlet or wall socket to made it off. If your desire and want to shut it down.
Then final option, Find the Thermostat control (Temperature control) If its digital theres a small lcd show the number and figures that control the temperature set up to start and off the unit.
It can be done by remote only.
On the other manual way you must find also the knob and rotate it clockwise to increase the temp and run longer.If reverse counterclockwise it decrease the temp. and turn it off quickly as possible. In case if it compose of slide control. Upward to increase and downward to decrease
All aircon unit has its panel board or LCD Screen that control the power on & off.
You can test the result by trying to put a power again on the unit.
I hope you you find my solution successfull. Until you locate and found the remote.
r_ic7
Posted on Nov 28, 2008
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
Air con turns itself off
Check that your timer is off on your remote
Feb 11, 2015 | LG LSC121PMA Split System Air Conditioner
Not cooling and shutting off, indicator light flashes
the outdoor indictor light on my lg split comes on after some minutes on the one inside and the cooling has reduced please can any1 tell me what the problem is
Jan 18, 2013 | LG LSC121PMA Split System Air Conditioner
LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Apr 13, 2009 | LG LSC121PMA Split System Air Conditioner
Cant turn air con of with control
if the remote is lg it haven't code the eye of the plate has burned
Feb 21, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
No Display on controller
Try replacing the battery but if it wont work you need to replace the remote control itself, but for the main time you can operate the unit by pressing the emergency switch button to operate the unit manually.
Jan 09, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Coleman Mach III Air Conditioner Logo
133 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
