Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Oven locked but not realy locked
On the display of my Kenmore shows a syble of a lock. but lt is not locked but it wont let me put the oven on. what do i do?
  • Anonymous Dec 24, 2008
    same problem but it is a different oven
    The oven is a Kitchen Superba Oven
    you can open it but just not do anything
    President:
  • Kenmore Master
  • 2,651 Answers
Your "control lock" is on. look closely at te htouch pad for that same symbol, there will be a button with it, or marked cntrol lock. press and hold for 3 secs, it will turn off
Posted on Nov 27, 2008
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    Self clean is locked but door still open
    oven won't heat, "door locked" always flashing if I push"off/cancel there is a crackeling noise and "F9" fashes for a while then stops, Display flashes "door locked" but door will open but will not heat and now always flashes "door locked"
    Dec 18, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
    Old kenmore built in oven wont unlock
    When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
    However....."broil" feature works just fine.
    Please help.
    Apr 09, 2010 | Ovens
    After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
    This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
    Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
    Jun 03, 2009 | Ovens
    E-1 F-5
    After cleaning the oven the oven door remained locked and this error displayed E-1 F-5
    Jan 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Kenmore door locked
    Try pushing and holding the door shut. Then moderately tap on the door where the latch is and it may come loose. Usually it is mechanical and not electrical here. Could also be if you have a self cleaner on it, that it is reading that you are cleaning the oven. If the first thing does not work, then turn off your breaker for about 15 seconds and then back on. Sometimes it may reset itself and put it back in working order.
    Nov 04, 2008 | Kenmore 47783 Electric Single Oven
    Kenmore model # 911.36765892 / sn BT293037Q
    The lock motor may have failed. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam.
    Jun 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Kenmore locked
    The www.managemyhome.com website has some troubleshooting options when the door wont unlock. Good luck. Also you can download the whole manual online it you have your model number. Mine was inside the drawer under the oven.
    Apr 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Kenmore double oven flashing locked door, door not locked, oven wont respond
    hey  i have the same problem, i moved into this house so i have no manuel. this is crazy, i hate this oven. i would personally never buy this oven. if you guys have figured out this problem i would really appreciate a response.  thanks Justine  Canada
    Nov 22, 2007 | Ovens
    Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
    107 people viewed this question
    Top Kenmore Ovens Experts
    Marvin
    Marvin
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
