Question about Sanyo Televison & Video
TV NOT WORKING
My TV doesn't come on when the power switch is pressed and, the power light isn't lit. I have put a circuit tester across the switch which appears ok. There also appears to be power at components beyond the switch.
Can you offer any advice/potential remedy?
Thanks
Bryn Powell
  • 153 Answers
Check at the Horizontal section and test for any defective transistors. This type of problem are usually at the Horizontal output. cheers.
Posted on Nov 27, 2008
Break lights and blinkers not working
If you put the tester on the outlets and it lights up properly but the bulbs dont, you have already concluded that the wiring isn't the problem. unless of course the wires are corroded and simply putting the bulb in shorts it out. Have you tested the bulbs?
Jul 22, 2012 | 2008 Pontiac G6
I have a IZIP I200 scooter I replaced the batteries and still does not woork
Although your device isn't a mobility scooter, they share many similarities. The following info should be of help to you
If when switched on you don't get lights you are not getting any power to the tiller head, the meter should be reading voltage regardless of the condition of the control circuitry. My first scooter was a very old AMIGO, it sat in a barn for 20 yrs, this was anything but a dry environment.As a matter of fact i has to a power washer to clean the two inches of Chicken manure off it. This scooter was so old that it has an discrete component open controller board as opposed to fully potted and enclosed LSI based controllers we see on todays scooters. The engager in the tiller was oxidized, and had to be cleaned and dried out. I rinse the controller out with distilled water then put it in a preheated oven at 150 F for 24 hrs. WARNING make sure of the temperature some ovens will not go this low. The newer controllers are potted and enclosed, making them water resistant, they use LSI which are proprietary and can't be purchased or repaired. I liked older controllers because you could fix them.
What you got to do is what we call "chase the voltage" First you will need a 24v circuit tester
http://www.amazon.com/OEM-25886-6-24V-Circuit-Tester/dp/B0014WIVX6
You may also need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
The problem is 24volts is either not getting to the tiller head or you have a broken wire in the tiller head. Start at the headlight make sure its switched on. Use the circuit tester, put the clamp to ground, use the probe to find the 24volts, The hot side is the side wired in series with the switch. The tester will light up when it has voltage. Chase the wire back through the system. When you get to a cable or anywhere you can't see the wires use the VOM meter, disconnect the scooters batteries leaving the power switch on. Set the meter to read resistance scale high scale, short the probes together, zero the meter. Put one probe at the headlight the other probe at the connector you think the wire ends up at. Normally every wire is a different combination of colors like red; with a white stripe. Most of the time a wire ends up at a connector and the color code doesn't change. So if you are not getting continuity on any of the pins on the connector you know its got to go, you've isolated the open circuit too the tiler head. Here's a test you can run! Turn headlight on, power on for scooter, disconnect scooter battery, place one probe at head light. Disconnect tiller cable. Probe each pin, one of them hast to cause the meter to deflect to zero. If if doesn't the problem is in the tiller head. When working with little wires i like to use crochet needles. You can use the meter to check cables each pin in must have a pin out. If you don't get continuity between pins the cable is bad toss it.
Jul 16, 2012 | Health & Beauty
Invacare auriga runs well but no headlight or indicaters any ideas
Jun 03, 2012 | Health & Beauty
Remote control does not work
The remote itself can be tested by any TV shop--point the remote at the tester (either a card with strip in middle or other) and press buttons on remote--tester will respond or strip on card tester will light.
Many digital cameras in a very dimly lit room will react the same way with a flash on the LCD display screen.
If remote itself is good that leaves the remote sensor in the set--usually on a tiny circuit board and can be replaced if set not too old.
May 29, 2012 | Hitachi Televison & Video
How to use a continuity tester
The most basic continuity tester (or test light or toner) are often said to provide a simple "go" or "no go" type indication (you'll see below that this is not entirely true). They usually are self powered by a battery, and have two probes to make contact with the circuit, component, wire, etc. under test.
Continuity testers are used on dead or un-powered circuits only. Likewise, they need to be tested prior to use to make sure that the battery, lamp, etc. are in good working order. Testing is done simply by touching the probes together. When connected to each other, note the intensity of the indicator - whether it is a lamp, audible alert or other indication. This is your 100% continuity reference indication.
If there is a complete path or circuit between the probes on the tester, an indication will be given. This could be brightly lit lamp, tone or buzz sound from a speaker, etc. A circuit with only fair or poor continuity may provide a dimly lit lamp or a "sick" sounding buzzer. Keep in mind that some items under test may have very poor continuity - say 20% or 30% or other unknown value that will not be sufficient to provide an indication - but will still conduct. This should alert you that a continuity tester really isn't a "no go" indicator. This is important to remember. This is where an Ohm meter shines when compared to a simple continuity tester. It will pinpoint just how much continuity there is in a circuit.
I hope this helps!
May 12, 2012 | Measuring Tools & Sensors
I have a 98 ford explorer eddie bauer and my horn is no longer working. is this a fuse issue and if so which fuse do i change?
Fuse controlling the horn is usually a 15A fuse located in the Distribution Panel under the dash.
Usually there is a cluster of fuses running 4 across and about 8 down on this panel.
So, look for all the 15A fuses in this cluster and check with a circuit tester.
If you check each side of fuse and get the light...then fuse is good.
If ya get light on one side and not the other...you've got a blown fuse.
Before you do this, disconnect the wire off the horn and connect circuit tester to the horn's power wire / socket and press horn switch on sterring wheel.
If you don't get the light glow...then check your fuses.
If you get the light glow...then your horn is bad...and they do go bad.
Hope this helps.
Jul 23, 2011 | 1998 Ford Explorer
My AA Mini Maglite needed a new bulb, and I am upgrading with a 3 white LEDs and a tail cap switch ... but now nothing I try can get the torch to work. Can you possibly, help, please?
You've introduced two variables to your flashlight, and each needs to be tested independently. It's possible that one--or both--isn't working properly. It's equally possible that one or both of these replacement parts isn't perfectly meshing with the conductive areas of the maglite body, meaning that they're not completing the basic circuit needed to power the light.
The best way to test your tailcap switch is either to try it with another maglite or test its continuity with a multi-tester. With the tester, you should be able to toggle between readings of infinite resistance (switch off, no circuit) and little or no resistance (switch turned on). If you're stuck at infinite resistance, there's a problem with the switch.
You could test the LED insert by using test clips to touch power to the module to see whether it will light up.
My guess is that the components are probably good, but that somewhere along the line, there's a break in the basic circuit. My leading suspect would be the connection from the LED module to the negative (flashlight body) side. It could be that the module is slightly out of round and it's simply not making contact. It could be that the finish of the maglite is acting as an insulator. However, I would recommend deferring this analysis until you've confirmed that each component works fine.
Jul 12, 2011 | MagLite Rechargeable Flashlight System
Have a 1999 Chev. Suburban. Problem is with brake lights. Top panel (on roof) works but neither side panel works. Replaced circut boards in tail lights, new bulbs, and all fuses are good. What next?
WITH A GOOD FUSE TESTER, TEST ALL THE FUSES FUSEBOX UNDER THE HOOD & INSIDE THE VEHICLE. IF THE FUSES ARE ALL GOOD WITH THE TESTER YOU MUST HAVE A BAD BRAKE LIGHT SWITCH OR A BAD TURN SIGNAL SWITCH. THE BRAKE LIGHT CIRCUIT GOES UP THROUGH THE TURN SIGNAL SWITCH & THEN TO THE BRAKE LIGHTS. FIRST OF ALL IS THE BRAKE LIGHT SWITCH GOOD ? THE ORANGE WIRE FEEDS THE BRAKE LIGHT SWITCH, THE WHITE WIRE PUTS POWER TO THE TURN SIGNAL SWITCH, SO THE LIGHTS CAN BE USED AS TURN LIGHTS OR BRAKE LIGHTS. , PUT A TESTER IN THE WHITE WIRE & PRESS ON THE BRAKE PEDAL. IF THE TEST LIGHT LIGHTS UP, BRAKE LIGHT SWITCH IS GOOD, BY THE WAY THE BRAKE LIGHT FUSE MAY BE LABELED" STOP", THE FUSE LABELED" BRAKE" IS FOR THE ABS SYSTEM. TO CHECK THE TURN SIGNAL SWITCH FOR BRAKE LIGHTS, REMOVE THE PLASTIC COVER FROM UNDER THE STEERING WHEEL, PRESS ON THE BRAKE PEDAL, PUT THE TESTER IN THE SMALL YELLOW WIRE, THEN THE SMALL GREEN WIRE. IF THERE IS NO POWER IN EITHER WIRE, THE TURN SIGNAL SWITCH IS BAD.
Jan 11, 2011 | 1999 Chevrolet Suburban
I have a Ryobi RE175. It just stopped working
1. Shut the power off, and disconnect your Ryobi
router. It could be the start/stop switch. So, you
can begin checking the switch contacts using the
multi-tester. Set if at 1 x 10 Ohms. Put the probes
of the tester across the switch terminals. Pressing
the trigger on will move the tester indicator to zero
if your switch is okey. Otherwise, no moverment -
the trigger switch need replacement.
2. Should the trigger switch proved to be okey, Check
the carbon brush of the unit, short carbon brush??
you have to replace it.
Nov 03, 2009 | Electrical Supplies
Laptop won't turn on
No I think U have problem with ur mother board..
Nov 29, 2008 | Toshiba Satellite A105 Notebook
Televison & Video Logo
54 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
