Question about Dell Inspiron 6400 Notebook
Laptop gets very hot after one hour
After using my dell laptop, it gets very hot from the bottom and iam worried and thinking this is not normal.
  • 1,142 Answers
I ll give you a good suggestion as i have worked for dell and i know this issue very well, If this is under warranty it can be replaced by dell itself or else the will do a recall for the unit in shock hazard policy whether it is under warranty or not. Al you need to do is call the 800-6249896 toll free and tell them that ur system is getting extremely hot and ur getting shock in case you touch andy metal part they will replace it for free.
Posted on Nov 27, 2008
Dell 2709 LCD gets off.
It is getting hot. Use canned air to blow it out.
Nov 27, 2013 | Dell UltraSharp 2709W LCD Monitor
Notebook getting hot on bottom
How hot? Too hot to touch, or just warm? Are you allowing adequate airflow under it? If you set it on a pillow or a blanket, you will restrict airflow, and it will heat up. If it's getting adequate airflow and it's getting hot enough that you think it could burn you, contact Dell for service. Use the term "too hot to touch" and you will most likely recieve a call tag for service. Be prepared to wait several weeks to get your laptop back though. They are SLOOOOOOW with service.
Jan 06, 2013 | Dell Inspiron 300M Notebook
My Dell Latitude D820 has many problems.... The biggest one is that I came home from work to turn it on, and the screen is black... When it turns on, it is completely white. I am so upset! I just got this...
Screen issue:
It sounds like either the lcd screen or video card inside the computer is bad. To isolate the problem try connecting an external monitor to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the external monitor displays ok that proves your video card is ok and your lcd screen is the problem. If the external monitor displays the black or white screen like your lcd screen then your video card inside the computer is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Laptop hot:
Some laptops and the ac adapter get very hot. If the laptop is not shutting down, then it is not overheating, so don't worry about it. You can buy a laptop cooling pad that has fans on it and it plugs into one of the usb ports on the laptop. The laptop sits on it to keep cooler.
Your battery is probably dead so that is why you can only power it up using the ac adapter power cord. Once the power cord is removed, the laptop will turn off. Batteries only have a useful life, and after that, they have to be replaced.
May 21, 2012 | Dell Computers & Internet
Hi.I have a dell xps m1330. after use for an hour,...
put a cooling pad under the laptop, make sure there is plenty of air movemend by the fans, example. dont sit the laptop on your bed or a pillow or anything that blocks air movement. also, they will tend to get hot if you put a lot of high usage on them as in gaming and such. if you have tried all these and it gets so hot that it locks up or is burning, you, then call Dell it could be an internal issue.
May 20, 2010 | Dell XPS M1330 Notebook
The laptop gets very hot very quickly.
This happnes to my one aswell cause of the battery battery life stays up to 2 hours ...after 30 mins it gets hot and i phoned the company (dell)..they gave me a new one which works perfect ....but you have to have insurance on the laptop
Apr 16, 2010 | Acer Aspire 5610-4648 Notebook
I have a Dell XPS M1210 laptop for which I have just purchased a new 9-cell compatible battery. It worked great for a couple of hours, but now shuts off immediately when unplugged from the AC power supply....
You might want to try what I did when I had a completely discharged battery for my Dell Laptop. I attached the battery to the computer, make sure the computer is off and plug in the charger for a full twenty four hours (undisturbed). And this really worked. I had no problems with the battery. Good luck.
Feb 26, 2010 | Dell XPS M1210 Notebook
Dell Laptop Studio 1535
hi marob,
perhaps cleaning the fan inlet with compressed air can remove some of the dust inside so that the fan can work properly, additionally you may remove the battery pack and let the machine rest on four sockets (one at each corner) to improve ventilation and to prevent overheating.
good luck
Sep 30, 2009 | Dell Latitude D600 Notebook
I have a light flashing from green to orange on my laptop
no worries its just reading.. datas..
hot is just normal..
Sep 25, 2009 | Dell Latitude D610 Laptop Computer -...
Screen gets hot and turns black on the bottom right
There are many causes of this. On cause can be the Cold cathode fluorescent
tube itself. This is a grossly misnamed device as the cathodes get very hot
indeed. One of the tube failure modes as they wear out is that the cathodes
can get much hotter than normal, and this affects the screen near it.
Jun 24, 2009 | Dell Inspiron 6000 Notebook
Dell Latitude D600 hot
this is perfectly normal. Ram is constantly written to and erased thousands of times a minute. This causes it to heat up. On older laptops like the d600, they don't have a great method of cooling it down so it does get hot. Mine gets hot enough to burn me if i hold it wrong. Just make sure when you are using it, that the bottom gets away from the surface its on once in a while, and you should be fine.
Jan 20, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 6400 Notebook Logo
69 people viewed this question
Alun Cox
