Question about Sony XM-DS1300P5 Car Audio Amplifier
Amplifier On - No Sub Sound
I have a Sony XM-DS1300P5 amp. I disconnected my sub to fit some stuff in my trunk. When I reconnected the sub, I got no sound. I did not change/touch anything between disconnect/reconnect. I tested sub and it's working. Amp LED turns on and does not go into protection (stays green). All fuses are fine. I tried turning sub on/off in pioneer HU but no difference. WIth the car on (amp on), I switched RCA inputs to amp with inputs from my laptop but still no sound from sub (I don't know how good a test this was as there was probably very little lows coming from the laptop). Any suggestions?
  • Kev Vin Jan 11, 2007
    Thanks. Should have mentioned I tried new speaker cable from my amp to sub (definately not mixing up the +/-). There are no switches per se, just dials that can be set with a screw driver (I will check the gain and such tomorrow). Also, the amp is under the driver's seat, nothing can bump it. This is just weird. I can't see how the amp is not sending out a signal considering it's getting power and no fuses have blown.
When the subwoofer was disconnected was thre a chance of shorting of terminals?? If so connect a digital multimeter in Volts position and see if you get any voltage with a signal fed to the Subwoofer amp. Most subs have a fuse in line with the speaker for protection. If you are not getting any voltage then the fuse could have blown. Good luck.
Posted on Jan 11, 2007
    Scholar:
  • 72 Answers
Are you certain you put the wires back on the amp the exact way they came off. I am not familiar with this amp but most amps if you look at the terminals where the speakers hook up there will be a plus and a minus. And generally there are four terminals. hence stereo plus and minus left and right. Some even have eight for, four channels. Since the amp is on, not getting hot and you tried two different audio inputs I would suspect speaker wiring or maybe the stuff you put in your trunk bumped a switch on the amplifier. I know this is not the exact answer you are probaly looking for but it is at least a place to start
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
May 11, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
No power to amp.....all wire connected properly
is protection light coming on when sub is connected? some radios have weak remote that blow out easy..check power on it if power is making it to amp..if its an ANL fuse they can look good but be bad.
Jun 08, 2010 | Sony XM-1502SX Car Audio Amplifier
Is my amplifier finished
check first the fuse of your amplifier set maybe blown up then check also the switch of amp.
Aug 15, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Power acoustiks amp wont get off protection mode? how do i reset it? please help me i tried everything.
Hello nfox1987,
First you need to determine if the amp is defective or if something else is causing it to go into protection, most often a short in the sub or amp wiring.
Disconnect the sub(s) from the speaker output terminals and the RCA inputs from the head unit, and test if the amp powers up OK. If it does, the problem is in the sub(s) wiring or voice coils, or in the RCA inputs to the amp. Reconnect each one-at-a-time to determine exactly where the short is and repair or replace the defective wiring or unit. If it doesn't power up with the inputs and sub(s) disconnected, the amp itself is most likely defective.
Hope this helps.
Jul 15, 2009 | Sony XM-475GSX Car Audio Amplifier
Xplod XM-DS1600P5 red light
For some reason it has gone into protection mode to limit further damage to the amplifier. Remove the subwoofer wires and power on to eliminate shorted voicecoil. After checking all wires for continuity to ground, a service tech will be required.
Nov 30, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Sony XM-1252GTR Amplifier
Can it power the subs? Yes.
Can it make them crank? Well, that all depends on your expectations. That amp/sub combo is going to give each sub about 125W, which isn't much. But if it's what you have, it's better than nothing. You might also consider using only one sub and bridging the amp. This would put about 340W on the one sub, which is much more reasonable.
Mar 13, 2008 | Sony XM-1252GTR Car Audio Amplifier
No Sound/ lights flashing on Amp
Disconnect your subs from the amp. If the lights go out then your sub is blown and is putting the amp into protect. If the lights keep flashing even with the subs disconnected than the Amp is toast.
Jul 09, 2007 | Sony XM-752EQX Car Audio Amplifier
Problem
check the fuse, check the ground, hot lead excetera excetera make sure everything is still intact sony car audio's are very tempermental good thing though they are cheap to replace.
Apr 30, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Sony XM-DS1300P5 Car Audio Amplifier Logo
104 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
