Question about OEM Systems Ice Cube 3.5 inches FireWire External Hard Drive Enclosure (MT911FWHCL) Drive Case
Blue power light is flashing red and the hard drive won't mount
Hi there FYI- this site was one of the first to pop up when I started to search the web on this problem. I've never participated in a forum before so this is a bit new for me. Anyway, I was editing some video last night and all was well with the render/project files being saved to the external hard drive. After having shut down the G5 (PowerMac) at the end of the night, I forgot to power down the external drive, so it was left on all night (late night - no brains left). This morning after starting up the Mac, I noticed the external drive hadn't mounted on the desktop. I took a look and discovered that the blue power light was flashing red (intermittently between red and blue). I turned it off, removed the power supply and firewire plug, then reconnected them and turned it back on - the power light is still flashing red. We noticed that the fridge had reset itself overnight so I'm wondering if a power surge or temporary power failure may have caused this. We have a surge protector for our computer equipment. Any thoughts on what may have happened and what I can do next? Many thanks for this site and to anyone who responds - I hope I can be of help to someone else in the future.
  • Genevieve Ricci Jan 11, 2007
    Hi again
    Problem solved. No more flashing power light, external drive has mounted and all the files are there - what a relief! I'm so grateful I didn't lose any information.
    I surfed the net for the power supply specs for a current model MacPower IceCube of similar size to mine. The Output on the power supply I was using was 12V/1.25A when it should have been 12V/3A (Australian specs).
    We had moved recently and all our power supplies for various pieces of equipment got mixed up. Not sure why the one I was using worked and then didn't work (maybe it was running at its limit and whatever happened last night pushed it over its limit), but I feel better now that I'm using what is probably the correct supply.
    Hope this helps anyone else having power supply issues with their external hard drive. Feel free to clarify my comments if you're an expert on the subject (as I am most definitely not!).
    Cheers...
  • Genevieve Ricci Jan 12, 2007
    This is a message for tomj23 to say THANK YOU for responding so quickly. The answer you gave showed you took some time researching the problem and you also gave me an insight into how these things come together. You were so right in expressing the possibility of an undocumented error (most human errors are - I suppose the manufacturers can't think of everything!).
    So, it's all good and I really appreciate your effort.
    Enjoy the coming weekend (I think mine's coming a bit sooner than yours!)...
  • 624 Answers
Hi Vieve, The manual says nothing about flashing red and blue nor could I find anything of any real substance. Basically this thing is a box containing an IDE hard drive and some electronics that interfaces the drive with firewire, power distribution and a few other odds and ends. I suspect the board that contains the electronics may be damaged, however, its entirely possible that this may be some undocumented error that can be reset. I would try calling the vendors tech support, it?s at least worth a shot. If getting your data off is the concern it might be worth your time to buy another enclosure, install your drive and plug it into your Mac. There is a good chance your data is recoverable. Sorry I couldn?t get you a more definitive answer.
Posted on Jan 11, 2007
  • tomj23 Jan 11, 2007
    Looks like in the time it took me to write my non-answer you came up with your own, congratulations! Guess I should start refreshing the question page before I post ??..
SOURCE:
When I turn on the external drive, the lights flash.
It all depends on the type of your external. The different light color may indicate different thing. I would say that it may be an update being applied, a hard drive error or a power issue. I agree that this is not very helpful, but it all depends on the drive. Check your device's manual for some details about those lights meaning.
Hope this helps
Oct 14, 2014 | Computers & Internet
Lacie Case Only lighting up when HD is disconnected
I had the same problem with a 1TB hard drive. The fault was caused by the casing being knocked from the computer and falling onto the desk. If the hard drive hadn't been powered up it would have been ok...
I removed the hard drive from the casing and fitted it into my computer as a slave drive, hoping to access all the music and movies stored in it. No go .. But, it's worth you fitting your hard drive as a slave and trying the same. It's worth a shot.
I took the hard drive to a computer market here in China, where I work. These guys take hard drives apart to fix them, if possible. They couldn't fix my hard drive as it had been powered on when it fell ..
However, I bought a new desktop hard drive and they were able to transfer 95% of all things from the old hard drive to the new one. The cost of transferring from the old hard drive to the new hard drive was the same as the price of the new hard drive. That specialist service doesn't come cheap ... but it can be done. I paid simply because I didn't want to lose what had taken more than a year to download.
Try fitting your hard drive as a slave to see if you can access the information on it. If not, a new hard drive and the cost of transferring your music from your old hard drive may be the only course of action left open to you
Jun 05, 2013 | LaCie Big Disk External USB 2.0 1TB Hard...
Hi, my Transcend 500GB Hard Drive was working fine until it suddenly could not be detected by my Mac. When it was plugged in, the blue lights flashed but the presence of the device never popped up on...
This could eitehr be a physical problem due to drive damage or possibly a problem with the spindle. Can you hear the drive spinning up when the blue lights flash?
Jul 10, 2011 | Transcend Computers & Internet
The blue light does not come on the red power light flashes and the red power light flashes i see nothing on the lap top
it might have been dropped, if so it could have bent the little read pin inside causing it to not be able to function correctly, those little harddrives cant take a very big hit
Sep 18, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
Manual
use this site and put 220 in the search box - your explorer 220 is found and you can download the user guide http://www.plantronics.com/north_america/en_US/support/manuals.jsp;jsessionid=83D442E12D37E83038D66C83670075A9.delta#results
see page 14 for details of the lights
  • Powering on Blue flashes
  • Powering off Red appears and goes off.
  • Charging battery Red solid light.
  • Low battery Red flashes.
  • Pairing mode Blue/red flashes.
  • Missed call Purple flashes. Single press the call control button to cancel.
  • Ringing Purple flashes. Briefly press call control button to answer the call.
  • Press call control button for 2 seconds to reject the call.
Apr 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Toshiba a200 flashing power light .. blue blue red red HELPPPPPPP
Remove battery and power
Remove memory in lower socket, the one on the system board and try reboot with just power cord. May have bad socket
Dec 11, 2009 | Toshiba Satellite A200-0ET00X Notebook
Drive won't mount
The Blue and Red lights generally indicate a harware failure. If the failure is power supply or enclosure you can simply solve the issue by taking your drive to a PC shop and having the techs there remove the hard drive inside it and move the hard drive into a new enclosure. Once in the new enclosure have them test it to see if it works. If it does buy the enclosure and be back to your business, if that fails you will need the help of a data recovery pro to retrieve your data(assuming there's anything worth saving). If this is the case, the transfer fails and you need your data back, reply with your location(Country, State and City) and I will be happy to direct you to an appropriate facility to have your data recovered.
Hope this helps FixYa,
Chris
Sep 24, 2009 | Acomdata E5 (HD250FE572) 256 GB Hard Drive
Fantom titanium external light turns red on connecting
Red is a failure warning but if it only hasppens with the usb plugged in it's mostly likey a failure in the IDE/SATA to USB conversion board.
Take the drive to your local PC shop, ask the techs there to pull the hard drive out of your phantom and test it in a new enclosure. If it works there, buy the enclosure, if it doesn't reply back and let me kow your Country, State and City and I can recommend a pro to look at the actual harddrive if you need files recovered from it.
Sep 03, 2009 | Fantom Titanium Hard Drive
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
OEM Systems Ice Cube 3.5 inches FireWire External Hard Drive Enclosure (MT911FWHCL) Drive Case Logo
1,209 people viewed this question
Top OEM Systems Computers & Internet Experts
micky dee
Thomas F. Schneider
1400Slugg
Are you an OEM Systems Computer and Internet Expert? Answer questions, earn points and help others
