Question about Fuji FinePix S1000FD Digital Camera
I can't open the battery door
I can not open the door to replace batteries!
  • lokolamb Nov 27, 2008
    Thanks but, I had tried this already.
    I mean that I had already tried the embedded button marked OPEN. Thanks again for trying.
  • 136 Answers
Look carefully at the camera body. A symbol (small arrow) is embeded there for open the battery slot. Try it.
Posted on Nov 27, 2008
How do you replace battery in chamberlain remote, garage door model 2487355
Do you have the Chamberlain 248735S garage door opener? Chamberlain doesn't have a 2487355 garage door opener; there are the 248735 and 248735S openers.
Most of the Chamberlain remotes are simple to open. Use the visor clip or a flat blade screwdriver to pry the two parts of the remote housing apart. There should be an open space on one edge of the short sides of the remote where you can insert the blade to begin separating the remote housing. Once started, you may be able to separate the rest of the housing by pulling the two sections apart with your hands. See page 32 of the user manual to see a picture of the separated remote or http://support.chamberlain.com/articles/How_To/How-do-I-remove-and-replace-the-battery-in-my-remote-control-1484145519292/?q=change+battery+in+remote&l=en_US&c=Brand%3AChamberlain&fs=Search&pn=1 for the procedure. Replace the battery with a 2032 coin cell battery, if you have the 248735S. Replace the battery with the correct replacement coin cell battery for other garage door opener models. Make sure that the side of the battery with the + faces the section of the remote housing with the buttons. The manual for the 248735S is currently here: https://www.chamberlain.com/CatalogResourcesV3/en-us/shared/files/tucmanuals/114A4256.pdf . Support and manuals for other models of Chamberlain garage door openers can be found from their support page: https://www.chamberlain.com/parts-and-support .
I hope this helps.
Jul 30, 2017 | Building Materials
Are the battery replaceable? Or do we have to buy a new remote opener?
Yes you change the batteries in a garage door opener remote. You can find on at your local pharmacy. If you have to push the button several times and the batteries don't help you may need to replace the remote.
Feb 10, 2015 | Building Materials
My highlander 2008, the doors can be locked and open with key and remote but cannot open the trunk with key and remote
To make the rear door open, you have to hold the button for a while. If the battery is weak, that will drain the power and the door will not open. Try the other remote and see if it works. At that point, I would replace the batteries in both remotes anyway.
That would be the fastest and cheapest way to eliminate one possible problem.
If the inside open button works to open the door, I would say the mechanism is working fine and it is the batteries.
I had to replace the batteries in both my remotes at the 3 year mark. That should be about now, the second time, for yours.
Dave
Sep 01, 2014 | 2008 Toyota Highlander
I have a Canon Power Shot A470. I have replaced the batteries many times, always with brand new ones, and it still keeps telling me to change the batteries. What is the problem with it? How do I fix it?
Yes, but what batteries have you been changing? If the AA's, those aren't the clock battery. Open the battery door, and notice the tiny door inside labeled "CR1220". Pry that door open with your fingernail, and take the enclosed CR1220 battery down to your local drugstore to purchase a replacement clock battery. Drugstores seem to be cheaper for this battery (~$3) than retail outlets like W-Mart (~$7).
Aug 22, 2011 | Canon PowerShot A470 Digital Camera
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Mar 10, 2011 | Conair WW60X memory electronic Weight...
Craftsman 1/2 HP Model 139.53914 The wireless outdoor keypad will not open the garage door but it will close it. The two garage door openers work just fine and the indoor keypad works fine. Replaced the...
Sounds like it has lost signal strength and the door cuts it down to the point that the receiver never gets the signal when the door is in the way. If it did that before you replaced the battery then you will have to replace the keypad.
Dec 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage opener remote on my 2003 santa fe just stopped working. How can I fix it?
There is a battery in the remote.If the battery gets old the remote will stop working.Replace the battery and check.Also if your battery is new but still the problem is there then,try to open the garage door by keeping less distance between remote as well as the garage door.Also there is a sensor in the garage door.If that sensor is not functioning then this can be one issue.In some cases the internal remote circuit gets short,in that case the remote needs replacement.But does the garage door sensor light shows any sign of getting connection from remote when you press the remote button.Open the door and try to close the door with remote and check.As per the problem,in most cases its weak battery related problem,and replacing the battery solves the problem.You can try all the possibilities and see which one helps.Thanks.Helpmech.
Nov 12, 2010 | 2003 Hyundai Santa Fe
I have a Chamberlain opener and it uses CR2032
Something in your remote is using power all the time. You need to replace it.
Nov 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to reprogram door locks for 2004 Toyota Camry
I recently replaced the battery on my 2004 Toyota Camry. When I installed new battery the door locks will not stay unlocked once opened with remote. How do I reprogram?
Feb 21, 2009 | 2005 Toyota Camry Solara
Fuji FinePix S1000FD Digital Camera Logo
208 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
