Posted on Nov 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Everytime I switch on the printer a test sheet is printed automatically
Anobik Som
Level 2:
  • Expert 136 Answers
  • Posted on Nov 27, 2008
Anobik Som
Expert
Level 2:
Answers
136
Questions
Helped
41467
Points
391
Which Printer you use?
Anyway....go to Start > Printer & Faxes > right click on your printer
and check off "Print Test page"
It will help you
Installed new ink. it says out of alenment
Dennis: According to an old FixYa.com, urbanhookupz said: "You need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
now try and print it should solve the problem.
if it does not prompt you to do a test page
Aligning the Print Head
This operation must be carried out when using the printer for the first time.
Aligning the
Print Head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic Print Head alignment only.
?? Ensure that the Inner Cover is closed.
?? The Print Head can also be aligned from the printer itself.
1.With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2. Hold down the RESUME/CANCEL button until the POWER lamp flashes four
times.
1 With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 28.
3 Print the pattern.
(1) Click the Maintenance tab.
(2) Click Print Head Alignment."
How do i switch of align page when installing a new cartridge as it waste paper printing a test page everytime you switch it on. This is for a HP 1300 series
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=238320&taskId=110
Click on the 'Automatically check to see if your driver needs updating (MS Windows Only).' box in order to check for latest updates to your driver.
Unfortunately, I looked over the unexpected page output and it didn't list this problem as one of them.
Does it really print a test page every time you switch it on? Or does it only print a test page after installing a new cartridge?
Definitely, the alignment page should be printed everytime a new cartridge is installed due to variations in manufacturing of print cartridges will throw off the alignment everytime a new cartridge is installed.
I'm not sure about the test page, though.
Good luck on this modification of standard operating of hp printers.
How can I stop my printer automatically printing out a test page when I switch it on?
every time u switch on the printer it will print the alignment sheet until you scan it.once the alignment sheet is printed ,keep it in the scanner glass and press the scan button.this will scan the alignment sheet.
Every time I turn on my printer, a Dell 948, it prints a page
Hi
We have 30+ printers... which we use for testing empty inkjet cartridges prior to refilling with ink. Basically we inject a little Magic Inkjet Flush directly into the dried print head which allows us to unclog them. Then we soak them overnight on Magic Pillows which gives just enough to do a PRINT TEST next day.
As some of our printers always try the alignment test here´s what we do...
1. Pull paper stack slightly away from printer, when it tries to print it thinks it is out of paper and should offer a cancel print option.
2. Alternatively if you print daily? Try leaving your printer power on... Some do alignments every time you power up... so dont switch off (they use very little power in standby.)
3. When exchanging inks like HP immediately switch off printer which cancels the print test. Then just switch on again.
4. Reinserting your printed sheets each time will save paper if not ink.
Good Luck!
Tinteiros (Ebay)
2answers
Test paper
Can only think that if the printer has a menu screen there may be an option to turn off that function. If it is only happening when you use it within office software...that the option is there to switch off the function......more often than not that is the case.
2answers
Will not print test page or documents
  • Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
  • While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
  • Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
  • Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
  • Press the PAUSE button. The printer begins printing the self test.
  • To stop printing temporarily, press the PAUSE button.
  • To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Printing Test Page
you probably need to align the print cartridges. you can usually do that through the advanced printer oprions
2helpful
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
k24674
Grand Canyon Tech
Grand Canyon Tech
