Question about Lexmark P4350 All-In-One InkJet Printer
Unsuported catridge 33 in lexmark p4350
The printer was working fine then it came up with unsupported catridge, so i changed it for a new one, still won't reconise it
  • 52 Answers
It is most likely that your printer has a hardware problem. Either mainboard or "printerhead assembly". Re-install the drivers again, if the re-installation does not work then seek advice on cost of hardware parts.
Posted on Nov 30, 2008
Lexmark 4350 wont print with unsupported cartridge
That's the reason why Lexmark does not recommend the use of refilled, refurbished or remanufactured cartridges. You may not get the quality and performance from the ink cartridges that is specially formulated and manufactured by Lexmark. I would highly recommend that you replace your refurbished cartridges and use original supplies.
Jan 05, 2012 | Lexmark P4350 All-In-One InkJet Printer
I'm getting error 1203 on my Lexmark P4350. I do not have a manual, I lost it. Thanks.
It seems that it's caused by your catridges overflowing, even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge.
Jul 26, 2011 | Office Equipment & Supplies
I need to download the setup disc for my Lesmark P4350 granddaughter misplaced it put new refills in and it wont recognize have been using it only as a copier printer not hooked tyo computor
You can download and install the Lexmark P4350 driver by visiting the Lexmark website at http://bit.ly/bETkq1. Select your operating system, download and then execute the file. However, if your main problem is the printer not recognizing your cartridges, make sure you are using the correct cartridges for your model (Mono: 32, 34 and Color: 33, 35). You could try to re-seat your cartridges by removing it from your printer. Unplug and replug your printer into the power source to reset it. When the printer turns on, reinsert the cartridges properly. Hope this helps.
Apr 14, 2011 | Lexmark P4350 All-In-One InkJet Printer
Damn.
Did you check the contacts on the color cartridge? It should be that green PCB board usually i know sometimes they put tape over it maybe there is a small piece that may still be sticking to it and not making good contact.
Sep 09, 2009 | Lexmark P4350 All-In-One InkJet Printer
I refilled my lexmark color printer #33 and now the printer will not accept it. I reads "unsupported cartridge see user guide #1203.
Go to Lexmark on screen trouble shootin suit and change cartridge from there. make sure the golden contacts on cartridge and printer both are dried and clean.
Oct 18, 2008 | Lexmark Office Equipment & Supplies
Lexmark P4350 AIO incorrectly identifies cartridges, will not allow printing
Some times refilled cartridges works fine,and in Lexmark cartridges
they do not support refilled onces ,Try a new compatible cartridge it should print ..
Feb 12, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 print catridge does not move.
i also have a lemark p4350 printer that wont work i find the best way is to put it in the bin and buy a different one im going for the canon or the epson ....top tip gray
Jan 19, 2008 | Lexmark P4350 All-In-One InkJet Printer
Error 1203
  It's mean your catridges overflow even from brand new catridges. After  several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge is located.
Solution:
 use  kleenex with a few drops of water to dampen and clean off those contact on the holder.
The refill ink works very well if you let it sit 24 hrs. Then before you print anything, you should run align  catridges a couple times then run clean catridges a couple times.
Print the test page to see how it  looks and away you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Try and see if it's work for you. Good luck......
Oct 29, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
57 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
