My daughter touches the buttons on our tv and has changed the writing for the colour brightness all of those things that are normally in english are now in something like islamic or something and I dont know which one changes it back to enlish as I cant understand the writing.
  • Debs
    Debs May 11, 2010
    What is the make and model of your TV? I will try to find out if the is a way to reset it for you
    Problem Solver:
  • 5 Answers
Your daughter accidently changed the language mode from English to either French or Spanish. If you push the menu button
on your remote repeatly until you see a word that resembles
"language" then highlight it and push adjust (either right or left)
you may be able to set it back to English. Some sets have a
feature that resets the adjustments back to the original settings
if the TV is unplugged from the electrical outlet for a minimum of
15 minutes then plugged back in.
Hope this helps,
Posted on Nov 29, 2008
I have a 37” Acoustic solutions tv mode LCD3761F1080P . the language is not English when I go onto menu to change colour , brightness picture etc.. How do I change it back to English, I can’t find the...
The manual for your TV can be found here:
Page 30 talks about Navigating the Analogue TV
Menu System and Page 33 leading through that section has information on language selection.
Hopefully you will be able to follow the manual and button presses to find the setting you need.
Jan 20, 2018 | Televison & Video
My daughter sat on her JVC tv/DVD combo LTdd42J remote and now her DVD's only play in black and white, when watching the TV the colour is fine. I have tried looking in the settings but cannot fin
Cable damage is the first thing to check. If the cable is external this is an easy check by trying a new one. Otherwise it is probably internal cable damage or damage to the video output plug.
Feb 18, 2013 | JVC XV-S302 DVD Player
To adjust the colour and brightness of the tv
yes there should be a menu button, normally in the middle of the remote, than you scould be able to change all your settings.
Apr 19, 2012 | Televison & Video
Canon pixma mp480 need to change language, Daughters idiot friend was touching buttons and now it is in czech or hungarian. How do I get it back to english?
To change language.
Press the MENU button.
Press the down arrow button 7 times then OK
Press the down arow button 8 times then OK
Use the up or down arrow button to select english language.
Press OK
Oct 16, 2011 | Canon Pixma MP480 All-In-One InkJet...
Theres no brightness setting in menu. it only has cc sleeptimer and exit. how do i change the brightness?
You can adjust the brightness control on your 19PR19 Philips Tv. For that you have to go to picture contol menu
Do it as follows
To adjust your TVs picture control, select a channel and follow these steps.
[1] Press the Menu Button on the remote control to display onscreen menu.
[2] Press Cursor up or Cursor Down button until the word Brightness is hilighted. For each press of Cursor Up or Cursor Down button you can go through Colour, Picture, Sharpness, Tint, Colour temp etc, depending on the adjustment you want to make.
[3] Press Cursor right or Cursor Left buttons to increase or decrese the selected option. Ok.
Nov 17, 2010 | Philips 19PR19 19" TV
Color setting for Sony XBR Trinitron 36" any settings
I thinks that you need to set its colour and other parameters, and posted this problem. If so there is adjustment at the first "Menu" option itself.
Press "Menu" button on your TVs remote control. You will see "Video" function as first selection on the screen. Use "Prog Up or Prog Down" keys to select and hilight the desired parameter. Use "Vol up or Vol down" keys to change it as your taste. That is all.
Normally the "Contrast should be more that 55% to 60% of its total value to get a clear and vivid picture. Colour and brightness are according your individual taste. Ok
If you wants to reset your TV to factory settings,
Turn on the TV.
Hold down "Reset" button on your remote handset and keep it pressed.
Press and release the power button on your TV front panel. the TV will turn itself off.
Release the "Reset key". Ok
Oct 26, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My color is washed out and dim and the colors are wrong . Toshiba 65h83 projection hd tv
I don't know your model, therefore I will tell you genericaly what the problem may be.
There are many things that can cause this type of fault. The response of the video amplifier stages would have to be checked right up through to the output that drives the projection. it is also possible that there is a fault with the colour demodulator. If the set uses projection tubes it is possible that the tubes are weak, or there is dirt in the optics. Colour demodulation problems can also cause the colours to not be correct. Many models using tubes have an optical transparent cooling fluid in front of the tubes. This fluid may have to be changed.
Feb 23, 2009 | Toshiba 42H81 42" Rear Projection...
Nintendo ds
You can change the system language with the following procedure:
1.) Go to the main menu.
2.) Touch the DS icon at the bottom of the screen.
3.) Select the pink icon, then a menu will appear. Touch the
3-D sphere to show the languages.
4.) Select "English", press the A Button, and your done!
Have a Happy New Year
Dec 28, 2008 | Nintendo DS Lite Console
Red screens cause flickering
if normal tv is fine then ,likely the signal from the box is too hot.
if using composite switch to cable ch 3 or vice versa,
or use hdmi cable or change the box .
Apr 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Colour fade of my 793s
rainbow colour is normally due to magenatic effect on monitor
see that any magnetic thing is near monitor
 if it is there remove it
.after that put off monitor for 15 minutes & then put on.see if any change is there
 if there is any change is there wait for 2 or 3 days it will be ok.
if brightness is also less along with fad color then
 check for video output section & crt electrodes for normal voltage.
it that is also ok then crt is getting weak,
please be in touch with me unless it is solved.
hope this will help.
Oct 11, 2007 | Samsung 793S 17" CRT Monitor
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
