Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error msg: paper jam or empty paper cassette when it is full
The paper is not feeding into the printer.
It is telling me that the paper tray is empty, when it is in fact full.
Help please!
  • 3 more comments
  • Anonymous Dec 04, 2008
    error message, saying there is no paper when it is in fact full
  • Anonymous Dec 14, 2008
    I also get a paper out! error when the bottom paper cassette is full, and the feed switch is correctly set on the lower cassette. Would appreciate any help on this problem.
  • Anonymous Dec 16, 2008
    Paper feed rollers on back paper tray don't work correctly on my replacement refurbished mp830. (My original mp830 died in 8 mo. and my Staples extended warranty replaced it with a refurbished w/ 90 day warranty.) Paper gets caught as soon as it begins to feed. Cyber-Test suggested I clean the rollers with q-tip and alcohol, but that didn't make a difference. They're replacing it... again. I wish I had a solution to offer. I tried just using the front tray while I waited for the replacement printer, but now machine is reading a paper jam and I can't proceed, even though there is no paper in it. I wish I had a solution to offer.
  • rvmjag Jan 04, 2009
    i have always loved this printer, but am about to throw it out of my window. I have PRINTER RAGE!!! whenever I clean it with my air in a can, it works for a little while again.
  • vsm3000 Jan 15, 2009
    I have no idea that the "feed switch" could make so much sense. I had this paper feeding problem, after using the Cannon Pixma 830 for several months, my printer will keep exhibiting error message paper tray is empty "cassette" is empty?.
    I tried to clean up, start, restart, powercycle the printer, then use the maintenance tab to clean up everything "auto?.
    Almost about to bang the computer with a hammer, then I came searching for error on the google, I noticed this discussion.
    I checked the feed switch twice, my goodness, it started working?. I am still not sure what the heck this feed switch does. I haven't changed my paper feed config, but I realize now, some accidental touch on this feed switch, which would have changed the paper feed.
    Hey, whatever it may be, Thanks for the tips.
Click on the 'feed switch' on the front control panel- it might be feeding from the invisible drawer underneath and it might be empty. There is a light which will indicate which source it is feeding from.
Posted on Dec 05, 2008
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Sir! the problem of our kyocera mita fs 3800 is this that it gives us message that the paper is jam please open the cassette 1.and remove the paper. we opened the cassette 1 checked the tray but there is...
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Apr 04, 2011 | Kyocera Mita FS 3800 Laser Printer
My canon MP560 thinks that there is no paper loaded when I have the tray full. How do I get it to believe that there is paper?
Theres a cassette underneath and a sheet feed from the back. Make sure you have paper in the cassette tray, when it says cassette tray empty.
Nov 05, 2010 | Canon MP560 All-In-One InkJet Printer
13.01.00 jam in tray 2
This is a paper mis-pick error. it may feed the paper just a little onto the roller on the cassette. This usually means the rollers are worn out. 2 of them to change, 1 on the cassette and one inside. They both have blue plastic cores.
Apr 15, 2010 | HP LaserJet 4200dtn Printer
My printer is not taking the paper and is saying that the tray is empty. I can hear the mechanism making a sound as though it is going to take the paper but nothing actually moves to do it. It's as if...
Try the feed switch first, the feed switch selects either the top feeder or the cassette under the printer. If it is set for the wrong one you get that error.
Nov 17, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Error msg: Paper tray empty or jam, when there is not
Clean The Paper Feed Rollers Using The Unit's Operation Panel Ifthe paper feed roller is dirty, paper is not fed properly because thepaper feed roller slips. Cleaning the paper feed roller could resolvethe paper feeding problem. Please follow the instructions below toclean the Paper Feed Rollers directly from the unit. Caution:Since the cleaning process wears down the paper feed roller, performthis procedure only when necessary and no more than three (3) times.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
  3. Press the <Menu> button.
  4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
  5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
  6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  1. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  2. Tocheck if the rollers are clean, load a sheet of Letter-sized plainpaper in the same paper source you selected in step 2, and press the<Open> button.
  3. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Sourcesetting in the printer driver. If the option is not set to 'Paper FeedSwitch', paper will feed from the source selected in the driver.
Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Paper tray empty, or paper jam at back
Hello, I had same problem with my Pixma 600, when you lift the control panel flap to turn on the printer just below the on off button ther's a small icon of the printer with a green led at the top and one at the bottom. Press the button to the right to change either top paper feed to bottom tray feed or vice versa.Then try again, you may need to load paper in tray at bottom/front on printer.
Paul 'W'
Error 391: paper jam
See below for Error 391:
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Apr 04, 2008 | OKI C5200n Laser Printer
Paper Feed Not Automatically Switching to Multi-Purpose Tray
Sounds like the paper out sensor for the cassette is either broken or jammed. Pull out the cassette tip the machine on its back and you should see a black arm hanging down. This should be able to swing back and fourth freely. Unless it is missing or broken.
Jun 08, 2007 | Canon LaserClass 2050 Plain Paper Fax
Canon PIXMA MP830 All-In-One InkJet Printer Logo
256 people viewed this question
old marine
old marine
