My panasonic dvd recorder seems just to record 1hr and 1 minute of a programme then stops recording. I've tried different discs but it's just the same
  • DVD Guy Dec 31, 2008
    The recorder randomly stops recording. There isn't any set time period before it stops. I'm using Sony DVD-Rs, and have tried different recording modes.
  • 456 Answers
Make sure the disc quality is not set to HQ high quality otherwise disc time is shorter than SQ or SP standard quality standard play
Posted on Nov 27, 2008
Machine will not recognise a new disc when trying to copy a recording
Did the previous machine show EXACTLY the same problem, or did that machine have another issue?
Regarding this one, does the DVD drive respond well to playback discs, such as commercial release DVDs, or DVDs recorded on other machines? Does it play back CDs OK? If it passes these tests, move on to-
I suggest trying to record on different discs - such as a DVD-RAM, or on a different brand of DVD-R, or DVD-Rs from a different batch to your current ones.
If the machine succeeds here, all good and well, if it fails at this point, it seems the machine is faulty and should be returned.
Oct 09, 2014 | Panasonic DMR-EX773 DVD Player/Recorder -...
DVD/VHS Panasonic DMR ES30V.I have a "digibox which, via the Autotune facility, has input "Free to Air" stations. However,I can only record/replay digital channels 1 - 5.others e.g BBC4...
Greetings,
channels 1-5 gets signal from the digital receiver.
and the other channels are from the autotune facility connected to the TV ?
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Panasonic Televison & Video
Dvd recorder won't play disc
your recorder will normally give you 5 changes at different regions, and on the last region change that is the one that it stays on, although if you you have never changed the region go to> my computer>right click on your dvd drive>properties and on the hardware tab, your hard drive and dvd drive will show, highlight your dvd drive and click properties and click the dvd regions tab and look at the region to see wot its set at, if you still have 5 changes, it should be set at your region one, if there are no changes left you need to search and download a region free dvd programme to allow any region dvd to be played programme
Jun 10, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Trying to record on a DVD-R , after several minutes trying to load i get a msg saying it can neither read nor play this disc , check disc,,please help
I've had this problem with trying to record on CD-Rs also. DVD and CD recorders can be very fussy. You just have to get a piece of dust or a fingerprint on the CD or DVD that's being recorded onto and it gets kicked back as a check disc or blank disc..
Another problem is some recorders will only accept certain brands. I've had problems recording onto a SONY CD-R with a SONY recorder! So, in summing up, try a different brand or make sure the disc is clean. Sometimes just taking the disc out and putting it back in in a different position will make the recorder think it's an OK disc. Hope this helps.
Jul 22, 2012 | Samsung DVDR120 DVD Recorder
I recently purchased the Toshiba DR570KU DVD recorder. I live and purchased this machine on a small Caribbean Island,and with respect to local people they have no technical knowledge of what they are...
Hi -
I'll try to explain without confusing you any further, but if anything doesn't make sense, please let me know. The instructions on page 79 are contradictory, which doesn't help very much. The upper part of the page suggests you can create extra space on a DVD+RW disc by deleting titles, while the lower part, in the grey box, states you cannot. The bottom part is actually correct.
I'll split this into two sections - blank/unused and used discs then explore a few scenarios.
Blank/unused discs
A DVD+RW is typically 4.7GB and will record approx. 2 hours of video in SP mode or 4 hours inLP mode. If you record more than one programme, they will appear consecutively in the disc editing menu, and shown as numbered blocks in the Title List. The last block shown will always be 'EMPTY', but the actual size of this block can be all or none of the total capacity of the disc.
If you insert a blank DVD+RW disc into the machine and view the title list, you will see this:
Although you can't 'record' to a block labelled EMPTY, this doesn't mean you cannot record to this disc. The blank space on the disc precedes the block labelled as 'EMPTY'.
If you then record one programme of 1 hour duration in SP mode. the title list will look like this:
Once again, although you can't 'record' to the block labelled EMPTY, this doesn't mean this disc is full or that you cannot record anything else on it. The next programme recorder will appear between title 1 and the 'empty' block - as long as there is sufficient space on the disc remaining to record the programme.
If you then record a second programme of 1 hour duration in SP mode. the title list will look like this:
This disc is now full as 2 hours of video has been recorded in SP mode. However, if you'd only recorded 1 hour in total for these 2 programmes, you would still be able to record another hour of video in SP to this disc. The additional programmes would appear between the last numbered title and the 'empty' block - until the disc is full.
The empty block is always present and you cannot 'get rid of it', but it doesn't mean the disc is full or cannot be recorded on.
Hopefully, this goes some way to explaining it, but I still need need to explain what happens with used / full discs when you want to delete programmes and re-record.
There is a maximum length for messages posted on FixYa and I may be getting close to this, so rather than break off in mid-flow, I will continue the explanation for used discs in another message below this one. I will do this right now, but it will probably take me 20 minutes or so to write part 2, so keep checking back. It will be less confusing if you hold any questions until I've written part 2, but I will be happy to answer any after that.
Regards,
BElectric
May 02, 2011 | Toshiba DR570 DVD Recorder
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
I have recorded a TV programme to the Hard Drive. However - I started recording manually and forgot to stop recording. So I have a recording 30 hours long! I want to copy the first 90 minutes to a DVD....
I used the edit function. I fast forwarded to the end of the section I wanted to record. I then stop the fast forward and used the split function. This split the original recording into two parts - the first 1hr 38min which I wanted to keep and the rest. It saved as two files and I was able to copy the first part to DVD and discard the rest.
Duncan
Dec 13, 2009 | Lite On LVW-5006 DVD Recorder
Recording problem - DMR-E55
Hi Steve
Please see my earlier answer to this common problem >HERE<
Best wishes..
Sep 20, 2008 | Panasonic DMR-E55 DVD Recorder
LG HDD/DVD Recorder RH177
Hi. I have this machine and it will only fast transfer if the original hdd recording has NOT been edited (i.e part deleted/divided/combined). This is also in the manual p51/52.
Hope this helps.
Adam.
Feb 06, 2008 | LG RH177 DVD Recorder/HDD Recorder
Dmr-ex77eb-k
The Panasonics are very picky about the media ie brand and quality of the DVD blank. Try a different brand and see if that helps.
Nov 23, 2007 | Panasonic DMR-E80H DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
