Where can i purchase two replacement crossovers for my mmc650 speakers
  • 959 Answers
Radio shack
Posted on Nov 28, 2008
I just purchased 2 old Peavey SP-2 and SP-3 speakers. How do I wire from the crossover to the speakers so the horns and 15's are wired in correct.
These cabinets are self contained and you do not use a crossover with them. The speakers do NOT come out to separate connectors. You just drive these with an amplifier. DO PAY ATTENTION to the power rating... you are safe using an amplifier with a MAXIMUM of 150 Watts RMS per speaker cabinet. More than that and running them loud and you will be replacing the speakers. These will cover a 40 foot square room at comfortable level.
Aug 14, 2011 | Peavey SP2 PA Passive Speaker
My infinity overture 3 crossover does not work anymore (both sides of the crossover do not have any output. If I bypass it the speakers do work (obviously without the filtering) My question is how do I...
This is a 3-way speaker; specifically which speakers do you hear something from and which speakers do you hear nothing from? If the woofer amplifer is blown, for example, you will hear nothing from the woofers, but will hear sound from the midrange speakers and the tweeter.
Feb 14, 2011 | Infinity Overture 3 Speaker
Sound went limp i think it the crossover
Define limp. No highs or no volume?
Logically, what one thing would affect both speakers? Logically, how would a crossover failure mute anything but the tweeter?
So, what happened just BEFORE this problem appeared?
I'd look at the electronics.
Feb 25, 2010 | Polk Audio R40 Speaker
Need to replace the crossover in a Peavey SP4G Speaker, What is the Part # and where to buy it?
Need to replace the crossovers in a pair of Peavey SP4G Speakers, where can I find the part
Dec 28, 2009 | Peavey TLS115X Speaker
The tweeters in my yamaha NS-515F have blown. Any ideas where i can purchase suitable replacements?
http://www.partsexpress.com is a popular source for loudspeaker components.
Also, are you sure the tweeter's blown, and not a crossover component?
www.mouser.com carries many electronic components that could be used in crossovers.
Dec 02, 2008 | Yamaha NS-515F Speaker
Blown crossover in a Peavey Pro-Sub 15" speaker cab. Can this be repaired? If not, where can I get a new crossover? I went to Peavey's web site and this particular crossover isn't on there.
Yes it can be repaired. Your best bet is to locate an authorized Peavey service center and order the crossover from there. Most will sell the replacement crossover directly. The cost of the individual parts will not be significantly less than the entire module. Are you sure that it is the crossover that is smoked? It is unusual for the crossovers to go bad. What is the symtom of the speaker failure?
Dan
Aug 18, 2008 | Audio Players & Recorders
I have purchased brand new Jamo speakers A 320. Front and surround measure with ohm meter open circuit. Centre speaker Measure impedance 6 ohms. Is this a normal,i have also checked another set of the...
Most better low frequency speakers (woofers) measure about 6 ohms because the addition of crossover will bring the impedance up to 8 ohms. Even without the crossover, 6 ohms will not harm the amp or speakers
Aug 15, 2008 | Audio Players & Recorders
Bypassing the 150 watt blown amp with passive crossover
I'm purchasing 2 infinity 3-way passive crossovers on eBay with the same crossover freqs as my two overture 3's with blown amps. For 19.99 each, it's worth a try. Good luck to you!
Jan 06, 2008 | Infinity Overture 2 Speaker
How to wire in a cross over
You didn't say if it was active or passive, but here is both:
Passive crossovers are easy to install. By definition, the only type of connections they require are to your speaker line. They typically get installed between the end of the speaker wire and the speaker. Connection should be fairly simple, just like hooking up the speaker itself.
Now F-Mod crossovers modify the audio signal before it is amplified. They accept the patch cord from your receiver on one end, and then plug directly into the preamp inputs on your amplifier. They are also easy to install, and don't require additional wiring.
 An active crossover requires a little more work. You have to connect 12-volt power, ground, and a turn-on lead. The active crossover gets installed between your receiver and your amplifier. A lot of active crossovers have both speaker-level and preamp inputs, so they can usually work with either type of connection. The outputs will be preamp connections to your amplifier. Hope that helps.
Oct 05, 2007 | CTG 2 ft. Stranded Wire Crossover Cable...
14 people viewed this question
 Grubhead
Grubhead
