Question about HP Photosmart 2575 All-In-One InkJet Printer
HP2575 Problem with scanning docs or pictures.
Problem withHP2575 photosmart. When trying to scan, the following message appears: "The feature you are trying to use is on a network resource that is unavailable.....enter an alternate path containing the installation package..".
Eventually after several times clicking on cancel, the scanning may proceed. Reinstallation of the software is necessary, but after some time the problem starts all over again. Could you please come with a solution?
Rob Leijder
Hvad kan jeg gøre for at den virker, den skriver
Er det noget med netværket eller inastallationen, fejl i netværket
Posted on Nov 27, 2008
  • 903 Answers
When you loaded the software for the printer did you do the full installation? I have looked on various forums for this issue and it appears that it will work in HP Solutions, is this the installation package that it may be looking for?
Cannot scan a document ....message "no scan options" appears when I try to start the scan
do the following uninstall the driver of the printer then reinstall it again using its driver cd
Aug 09, 2011 | HP Photosmart 3310 All-In-One InkJet...
When i install scanjet 8270 on windows 7 professional.after complete they appear hp solution center on deskotp and photosmart. so the problem is when i try to scan documents or picture or other alse the...
Hi
Please go to the control panel and select the Scanner and Camera, hear you get your scanner, double click the scanner and try to scan the paper, if hear also give the same error then please reinstall your scanner driver,
click hear to download the driver
May 19, 2011 | HP ScanJet 8270 Flatbed Scanner
How to use my hp photosmart C5280 All in One scanner unsing mac leopard
When you install the Full Feature software for your printer, you receive the HP Photosmart Studio imaging software and the HP Utility printer management software. You can use either of these programs to scan, and can create custom settings in both.
In general, use HP Photosmart Studio to scan pictures if you want to edit them to adjust color, crop, remove red eye, etc. Use HP Utility to set up scan tasks you use often, such as scanning to a certain folder or software application, or attaching the scanned item to an email. If your printer has a display, you also use HP Utility to designate which scan tasks should appear on the printer display menu when you start a scan from the controls on the printer.
Make sure that the printer is connected to the computer. Turn it on. Place the item with the print side down on the scanner glass.
Use HP Photosmart Studio to start a scan: Click the HP Photosmart Studio icon in the Dock. Click the Scan button. Select your HP product in the Device Name list, if necessary, and then click Continue. From the Scan Profiles screen, click either Pictures or Documents. Click Profile Settings , and then adjust any settings in the Capture , Adjust , and Page Options (for documents) or Enhance (for pictures) tabs as appropriate. Click Scan. When prompted, select Yes or No to add another page to the scan. The scan preview opens then click Return to close the preview and save the scan. Type a name for the scan in the Save As box. Click the Format drop-down list, select the file format you want, and then click Save.
Dec 10, 2010 | HP Photosmart C5280 Printer
I am trying to scan and I keep getting an error message that says No scan options. refer to device documentation to troubleshoot. I see a lot of other people have had this same problem. I have the HP...
I had this problem also and came to find out that in order to scan, you have to go into your "PAINT" and go to "FILE" and scroll down to "FROM SCANNER OR PRINTER" and then follow the instructions. It works!
Dec 20, 2009 | HP Photosmart 2575 All-In-One InkJet...
Having a problem with the scan function on my HPC7280
Not too sure on this model, but if there was no options, perhaps the machine has not been set up correctly to scan to a folder or application.
This FAQ/Guide from HP shows you what you need to do to correct set up your printer to make scans.
Dec 11, 2009 | HP Photosmart C7280 Printer
HP Photosmart 3110 All-in-one - Scanner function not working
Scanning requires two-way communication between the computer and the scanner. Usually the error that you describe above indicates an issue with the USB connection. First, make sure that you are not using a USB hub. Try a new USB 2.0 (A-B) cable that is under 6' long. Try using a different USB port on the computer.
If the problem persists, check the Device Manager to see if you have a USB driver problem. (For most versions of Windows, press the Windows key + X to quickly access the menu with the Device Manager.) Expand the section labeled Universal Serial Bus controllers and look for an exclamation point or an X. Similarly check for any issues in the Devices and Printers section of the Control Panel. The All-in-One should be listed as a printer and a scanner.
I hope this helps. If you are still having problems, please add a comment with the OS version on your computer. That can help identify additional issues that could be involved.
Apr 04, 2017 | HP Photosmart 3110 All-In-One InkJet...
Cannot scan wirelessly from HP Photosmart 4580 wirelessly
I reinstalled the printer software and reconnected the wireless connection and it now works well. I read somewhere that registry cleaner software may remove HP files that are required so this time after the registry cleaner scan, I unchecked any HP entry or printer entry and the scanner is still working, however, only from the pc to the printer, I still cannot scan using the buttons on the printer.
Jun 06, 2009 | HP Photosmart C4580 All-in-One InkJet...
Can't scan PLEASE HELP!
SOLUTION: Download the latest version (v 7.7.2) of the HP software from the HP website at www.hp.com. Uninstall the previous software and then reinstall the downloaded software. WORKAROUND: Follow the steps below:
  1. Load the slides or negatives in the TMA and place it on the scanner glass.
  2. Open Image Zone and click on Scan Picture to scan everything.
  3. After the scan is completed, change the settings from glass to scan slide/negative from TMA. The unit will scan again and show the four slides or negatives in the preview.
  4. Click on the first picture in the scan preview and make the following changes:
    • change the dust and scratch removal/sharpness to none
    • change the resolution to 72 dpi
  5. Click on the second picture in the scan preview and make the same changes described above.
  6. Click on the third picture and then the fourth picture and make the same changes.
  7. Click Accept . The correctly scanned slide or negative images will be saved in the Gallery.
May 21, 2009 | HP Photosmart 3310 All-In-One InkJet...
Scanning
just use paint to scan your pic or doc.Click on startmenu>Go to program>accessories>paint>file>scan from scanner or camera
Jul 31, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 2575 All-In-One InkJet Printer Logo
112 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
