Question about Ariens 34 In. Zoom Series Riding Mower
Ariens sierra 1440G belt configuration
I recently pulled my cutting deck off to clean it. I went to put it all back together and I think I have put the belt on the wrong way because the blades wont spin anymore when they are engaged, the pully just spins becuase the belt is too loose.Is there somewhere I can get a diagram of how the belt is set out or is there something that I need to tighten in order to get friction on the belt/pulley
  • Anonymous Mar 31, 2014
    PULLEYS TURN BELT SLACK
  • 37 Answers
Hi, you may have more than one problem. There should be one belt from the mower deck going to the electric clutch pulley which is on the engine shaft. On the shaft there are two pulleys, one belt comes from the mower deck, and the other comes from the transaxle pulley. check to see if your belts are in the right areas.
If this doesn’t work for you, please write back. Thanks,
Posted on Nov 27, 2008
What size belt other than the deck belt do I need for an ariens riding mower 42" cut?
I usually visit the manufacturer's website and download manuals that provide specific information. You will need the model number and serial number of your machine.
http://ariens.custhelp.com/app/answers/detail/a_id/15/
Apr 06, 2016 | Ariens Garden
Why won't the blades engage on my Ariens 911403
Chances are the deck drive belt has been knocked off one of the pulleys or the drive clutch won't engage properly. With the spark plug wire removed, rotate the blades by hand and make sure they both move together. This verifies the blade linking belt is OK. Now engage the blade operating control and feel for resistance as you rotate the blades. If you feel no change in resistance, remove the belt cover and reinstall the drive belt over the pulleys and tensioner/clutch mechanism.
May 31, 2014 | Ariens 34 In. Zoom Series Riding Mower
Why dose my john deere ltr 180 have smoke near currung deck when i put the cutting deck down
the only thing other than a frozen pulley it could be check the routing of the belt it is rubbing somewhere.
Sep 08, 2017 | John Deere Garden
How do i replace a blade that had fallen off. 42 inch tractor. The main problem is how to get underneath the tractor?
To replace blades, belts, sharpen blades, etc. one must remove what is called the cutting deck from the tractor.
Once the deck is off the tractor, pull it out, turn it over and you can work on the blades.
Gary
Jul 10, 2011 | Ariens 42" Riding Lawn Mower Blade ...
1046 cub done 120hrs 12mths old replaced all pullies bearing use 5 belts in 12mths belts keep comeing off is this a problem with this modle 2009
hi,
on some cubs there are two holes for the spring loaded pulley adjustment arm. take the deck back off and look at the spring loaded pulley arm mechanism, if theres two holes , take the bolt out that holds the adjustment arm down and move it to the other hole. theres two holes for the spring too, try the other hole, make sure your spring isnt upside down. putting the spring back on is difficult. connect it to the front first then come around the back with a spare piece of rope, put it on the spring and pull on the rope to get the spring back on the mower deck. use eye protection and be careful.
jm
Apr 23, 2011 | Cub Cadet LTX1040 Deck Belt 2009 Only...
Cant find the PTO deck belt for a Ariens Sport Zoom Model 915031-1232. Ita a zero turn mower. The manual calls for belt # 07242700 cant find it anywhere! Help.....
I own this model as well. The manufacturer issued a "cutting improvement kit" for this model number. The belt number has changed as well. The number you now need is # 07242200
I am in the process of ordering one for mine right now. Good luck!
Apr 14, 2010 | Ariens 34 In. Zoom Series Riding Mower
Blades lose power when deck lowered
SOUNDS LIKE YOU NEED A NEW BELT
Oct 01, 2009 | Garden
Sony Cassette TC-WR535 BELT REPLACEMENT
Unit may have defective idler or gear. Have serviced
Aug 05, 2008 | Sony CASSETTE DECK Single Dual Cassette...
Ariens 34 In. Zoom Series Riding Mower Logo
1,081 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
