Question about Sony MHC-G100 Shelf System
Volume really low
I recently noticed that I turn the volume to the maximum (0dB) and I can only hear the volume really really softly. Anything that is not at max volume, I cannot hear at all. Any suggestions?
    New Friend:
  • 111 Answers
Sound mute problem.
are you with electronic knowledge to fix this?
i can help.
nuwan.
Posted on Jan 13, 2009
Nokia phone - in call volume very low and can't hear callers
Try the settings menu for in call volume to make it permanent
Jul 25, 2014 | Nokia Cell Phones
Sony BDVE870 Low Volume
use equalizer to increase volume
May 19, 2012 | Sony Audio Players & Recorders
Music wont turn up -- too soft to hear properly
It could be that the maximum volume limit has been switched on too low.
Go to settings then playback and then volume limit, the volume control shows the maximum volume it has been set to. Use the click wheel to select your maximum volume and then press the centre button to set the limit. Then choose done. Hope this helps.
Dec 10, 2011 | Apple iPod nano
Ihave purchase of emachine note book of acer. volume of the speaker is so low hat even one person can not hear.i have talk with service center of acer,but they told that this is a maximum volume of the...
I have had that laptop once and had the same problem. I knew that it was the maximum volume of the speaker so I purchased external USB speakers to connect to the computer and the sound was clear and loud enough to hear anything played on the computer.
Thanks
P.S. Please rate if this solution was helpful
Nov 01, 2010 | Acer Computers & Internet
Denon AVR 1910 Volume Level
My Pioneer VSX-36TX (circa 2002) does the same thing. Modern AVR's count up from minus something to 0db and go just a few db higher into 'plus' territory. It seems arbitrary but that's how it is.
Ask yourself this: who ever really turned the volume knob up to maximum on any amp on purpose, and had speakers survive it? In other words, why have all that capacity on a potentiometer if you never use it?
Little known fact: With that in mind, Bose Corp actually designed a product that intentionally used the full physical travel of a volume control - the Bose Acoustic Wave Music System.
Feb 11, 2010 | Denon AVR588 Receiver
Why do the volume numbers on old receivers start
This type of calibartion is known as a logarithmic scale.
The numbers refer to decibels below the maximum output of the amplifier section of the reciever, or decibels of attenuation (making smaller/quieter).
Without going through logarithim theorey, the logarithim (base 10) of 1 is 0. So if 1 is the maximum output of the amp, as you turn the knob down from maximum you are adding more and more attentuation to the output (relative to maximum) and so the loudness of what you hear goes down, even though the number on the scale is going up !
Most peolpe associate decibels with sound levels, but anything can be measured in decibels, so long as there is soemthing to reference it against.
Nov 04, 2009 | Pioneer VSX-D409
Sharp 32c231 volume too low
If you are using a cable box with this set, the problem may be in the box settings.
Try this:
open the settings menu on the box . You may have to select"more settings" or something like that title to find the audio selections.
Under the audio, you will find recording and viewing volume settings. put these to maximum and save.
Your volume should now be more than adequate.
May 03, 2009 | Sharp 32C-240 32" TV
Hear sound but cant get any real volume even at full blast
I was playing around with my Sherwood RD 6513 and adjust the the output level to its maximum, amongst other settings. This limited my output on the amp to a maximum volume of 65 not 90+.. Anyway i pluged in the microphone and done another 'auto setup' of the volume levels and distances, and this allowed the volume to exceed 65 again!
Also if you have an external source such as a DVD player - i would assume you have already checked its output volume setting?
Nov 23, 2008 | Sherwood RD-6500 Receiver
Bose Sounddock Volume Control Problems
Well, there really was nothing to it.
I let it dry out for the rest of the day and it went back to normal, thankfully.
:) Juliyana.
Jul 19, 2008 | Bose SoundDock Digital Music System for...
Sound
Set your SAT receiver to full volume and use your Sony TV volume control as the master volume control. If you use an external surround sound amplifier do the same thing using the amplifiers volume control as the master volume control.
Consider that all source devices that have the ability to control their output volume will output what they call line level 0dB when the source device is set for maximum volume. If you set the source device to 1/4 volume your output to the amplifier may be around -25dB or lower. Introduce that low of an audio level to the amp and you will have to turn the amp up to half way or better causing the amp to amplify noise too.
Jul 04, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
175 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
