Question about Dryers
Hotpoint TDL 52P tumble dryer stopped working. When switched on just get a high pitched electrical buzz and the drum does not spin
  • dixon23 Nov 27, 2008
    Thanks - done this and the belt is still tight?
    Does that mean it is probably the motor ?
    At £150 to buy it looks like a replacement might be better than a repair?
  • 3,463 Answers
Sounds like a broken drive belt.
R emove top cover and check the belt.
I t should be round the drum, check toi see if it is still tight..
Posted on Nov 27, 2008
  • Barry Coates
    Barry Coates Nov 27, 2008
    Hi.
    Re dryer problem.
    Could be a faulty start capacitor, this is located at the rear right hand side of the m/c inside.
    It will entail removing top cover and side panel. It is a round cylinder about 4" long by the side of the motor with wires attached to it.
    Hope this helps.
What could possibly the reason my amana dryer wont tumble and just buzzes when you push the start button
Could be a broken belt spin the tumbler by hand it if it spins real easy the belt is off or broke another thing to try if you have resistance when turning the drum have a helper for this one open the door and hold the door switch in set timer to a cycle and press start while holding switch and buzzing spin drum and see if it will continue to rotate while holding switch if so motor going bad
Feb 17, 2015 | Amana Dryers
Hotpoint TDC62p is making a buzzing/humming sound and the drum will not spin though it does move if you push it.
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
May 17, 2012 | Hotpoint Tumble Dryer Tdc60n Tdc60p Tdc60s...
Hotpoint TDL 14 Dryer. Motor is working but drum not turning?
Remove the top cover and check to see if the belt is o/k, or could be collapsed rear bearing, remove the rear cover and check the drum bearing.
Nov 22, 2010 | Hotpoint Dryers
Hotpoint TDL 31. Seal between drum and door seems worn
Yes espares.co.uk will have parts and advice, sounds like you could have bearing problems...if its noisy on spin....
Apr 08, 2010 | Dryers
Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
Hotpoint Aquarius Tumble Dryer TDL 31
Replaced with a new unit as not cost effective to repair.
Feb 16, 2009 | Hotpoint TDC32 Electric Dryer
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Dryers Logo
135 people viewed this question
Top Dryers Experts
