Question about Microsoft MSN Messenger Connect for Enterprises (u35-00006) for PC
Cant sign in to MSN Messenger it says Temporary Problem when i check the service site it says its running think i deleted a file
    Scholar:
  • 31 Answers
Hi there, my name is Alex and I am here to help solve your problem
A common problem to signing in to MSN Messenger is the date and time set incorrectly. You can locate this at the bottom right hand corner of the desktop. After setting the time and date correctly, you should be able to sign in without problem.
If Messenger gives problems and the date and time are both set correctly, exit MSN Messenger and exit the icon which is located in the system bar (next to the time and date) and then open MSN Messenger again.
I hope this problem helps..... If you have any questions or more problems, please feel free to ask me.
Posted on Nov 28, 2008
Error code 81000306 cant sign in
http://messenger-support.spaces.live.com/blog/cns!8B3F39C76A8B853F!13932.entry
Please go and read the solution right there.
Hope this helps.
Aug 18, 2010 | Microsoft Windows Live Messanger
Hello sir i cann't sign in to msn messanger whenever i try to sign in is shows me that windows live communication platform i think that there is a data error wlcommm.exe
1: press ctrl alt + delete
2: select the task manager
3: search for all related messenger programs/tasks
4: end them
5: restart messenger
good luck ; )
Apr 22, 2010 | Microsoft MSN Messenger Connect Service
I cant sign in yahoo messenger anymore? how do I fix this?
delete all temporary internet files, delete cookies, run any registry cleaner may your problem will solve.
Apr 05, 2010 | Yahoo Mail
We can't sign you in windows live messenger
Go to this link: http://download.live.com/?sku=messenger
Then click the download button. It will download a small file to your computer. You then need to run this.
Once you run this file, it will ask you to select the programs to install.
Here, you can select Windows Live Messenger, and tell the application to install it for you.
Nov 06, 2009 | Microsoft MSN Messenger Connect Service
Can't sign in Error message 8e5e0408
1. Hit "run" in the start menu
2. Type "regedit"
3. Open "HKEY_CURRENT_USER\Software\Microsoft\MSNMessenger"
4. Delete the folder called MSN Messenger
5. After this MSN Messenger Live will login as normal.
or...
If you're not comfortable editing the registry, you can run this small reg. file which does the same thing as posted above:
Remove Messenger Settings
Hope I helped MSN expert Dr Reed
Nov 05, 2009 | Microsoft Computers & Internet
'We can't sign you into Windows Live Messenger'
haha it worked for me i fixed my problem. Try this it might work or might not. Go in to internet explorer and make sure work ofline is not ticked or make sure theres nothing wrong with your internet explorer. Try downloading the latest internet explorer. :D Hope this helps
Mar 30, 2009 | Microsoft MSN Messenger Connect Service
Error code 8e5e0408
2. Type "regedit"
or...
Hope this helps
Mar 20, 2009 | Microsoft Windows Live Messanger
I cant install yahoo messenger 9 it says not valid win32
Try deleting all your temporary files.
  1. Click Local Disk(C:)
  2. Click Documents and Settings, Your Document Name
  3. Local Settings
  4. Temp Folder
  5. Delete all the files inside the Temp Folder
Delete all your cache, internet temporary files,and cookies
  • Open your web browser
  • On the toolbar menu, Click Tools
  • Delete all files (History,cache,temp files,cookies).
Uninstall your previous YM installation. Reboot your computer. Download and reinstall your Yahoo Messenger.
Dec 26, 2008 | Yahoo Messenger
Msn messenger live beta 9
THis is a known problem
go to control pannel and then add and remove program and unistall the Beta Version and then install MSN 8.5
that is the only solution as MSN is still working on this
Dec 16, 2008 | Microsoft MSN Messenger Connect Service
Windowslive messenger not responding keeps coming up error8100030d
Error: 8100030d If you are receving the error code 8100030d when signing into Messenger, do the following: 1. Determine what version of Messenger is installed on the computer, and then upgrade Messenger if it is required: 1.a. Click here to determine the most recent versions of Messenger for each operating system. If you are not running the latest version for your operating system, please install the most updated version. 2. Delete the cache files for Messenger. Follow the steps below based on which version of Messenger you are using: 2.a. For MSN Messenger: 2.a.i. If you are running Windows XP or Windows 2000 click Start, click Run, type cmd , and then click OK to open the command window. 2.a.ii. If you are running Windows 98 or Windows ME, click Start, click Run, type command , and then click OK. 2.a.iii. At the command prompt, type the following commands. After each command line, press ENTER:
cd\
cd %appdata%\microsoft
cd "msn messenger"
del /s listcache.dat 2.b. For Windows Live Messenger: 2.b.i. For Windows XP
  • Right click on the Start button and then click Explore to open Windows Explorer. On the Tools menu, click Folder Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Click to clear the Hide extensions for known file types check box . Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them
C:\Documents and Settings\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Documents and Settings\ Your Windows logon name \Local Settings\Application Data\Microsoft\Windows Live Contacts\ Your Messenger email address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
2.b.ii. For Windows Vista
  • Click Start and then click Explore to open Windows Explorer. On the Organize menu, click Folder and Search Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Clear the Hide extensions for known file types check box. Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them.
C:\Users\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Users\ Your Windows logon name \AppData\Local\Microsoft\Windows Live Contacts\ Your Messenger e-mail address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
3. Try to sign in to Messenger again.
Aug 24, 2008 | Computers & Internet
Computers & Internet Logo
106 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
